01 Montero Sport 3.0L:Timing Tensioner question #1079995 02/15/16 03:37 PM
redraif Offline OP
Please help and thank you for your thoughts on this. smile
The question: Will the hydraulic portion of the timing tensioner fail if the pulley portion is left disconnected and the SUV is driven for a time?
Now for those who you might want to know the back story...
Shop screwed up hiring a wreckless tech (who he is now fired) that left my timing tensioner pulley disconnected when he put the sport back together after a warrantied water pump failure. (I had to pay labor, but not parts)
Tensioner ate through the timing cover made a wonderful clattering noise.
Shop replaced timing cover on their dime, but not the tensioner. While it was at the shop I expressed my concerns that the tensioner had been exposed to stresses beyond what its designed for and I thought it could fail due to this. (being left disconnected daily driver and eating through timing cover). Owner said now everything looks good the tensioner is fine. Truck is buttoned up.
A few days later, the clatter noise that cued me in to the situation to begin with, is back. Only at start up for a minute or so, and only intermittently. I inform shop and since its not every time, service clerk wants it videoed. As they need to hear it to diagnose. Well like all things it never does it when you are videoing.
Then I notice AC is out. Investigation shows the pulley bolt is only finger tight and the belt is slopping. Tighten it up... pray that is the noise. No joy... noise comes back.
Then the other day the clatter comes and stays. Now finally I can prove the noise exists to the shop. Noise is horrid and with research I'm 99% sure its the tensioner. I have the truck towed. I don't want to risk it skipping timing or throwing the belt. Sure enough the tensioner is dead.
Now the fun begins... The shop says they only left the pulley part disconnected before, but the hydraulic part failed. Since they did not leave the hydraulic part loose, its not their fault.
-I say, "but I told you to replace the pulley assembly."
-"Yes I remember" he says, "but it looked and acted fine."
-"Yes" I say, "but I told you I was worried it had stress from rubbing through the cover and being forced to ride at a odd angle."
-"Well the hydraulic part is separate", he says.
-I retort, "OK, but don't you think that the pulley portion being disconnected and not making proper contact would effect the hydraulics"...
-"well" he says...
So it was punted back to me to research.. frown I'm learning these motors bit by bit, but I have never had to use a tensioner like this. I need to know from you guys who have been there and done that...
After this the wife is buying a new car, so our daily driver is not constantly at the shop. As for me...Lesson learned... the next job I'm doing on my own or finding a Mitsu only shop!
Alpine White 2001 Mitsubishi Montero Sport XLS 3.0L 4WD Automatic
Re: 01 Montero Sport 3.0L:Timing Tensioner question [Re: redraif] #1079997 02/16/16 06:20 PM
redraif Offline OP
Ok so back and forth we went, the shop and I...
Best I can get with full mitsu dealer parts, plus tax = $450.57
Break down... $319.41 for parts (2 cam seals, crank seal, timing belt, timing tensioner)
Labor for seals... 1.6 = $112 (got to check on this... thought only 1 hour for all seals) anyway...
Free oil change with my choice of oil, so they don't loose my business... ha!
No labor charges for the rest.
I guess since I said, "if you had replaced it when I said it before". Guess that one would have been on me since it was preventative.
I tried my darndest, but I SUCK at negotiations. Seriously I was not built with haggling skills. But in the long run they had me over the barrel and did not have to do anything!
Might be divorced over this one. Lord help the Sport if it has another issue or does not clear its emissions codes... the spouse has a match ready for him! UGH!
Re: 01 Montero Sport 3.0L:Timing Tensioner question [Re: redraif] #1079998 02/16/16 06:35 PM
redraif Offline OP
Just got a call. They opted to drop ALL labor... so 338.57.
Guess it hit home when I said the blew my civic clutch budget.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.5971 MB (Peak: 0.6557 MB) Data Comp: Off Server Time: 2026-07-17 05:22:16 UTC
