engine cut out #102332 11/21/02 08:39 PM
SHERRI_GIRL Offline OP
I was driving my Runner last night, cruising on a level road at about 60mph when suddenly my engine just cut out for about 1-1 1/2 seconds, then just picked up like nothing happened. The lights, stereo etc. remained on. I thought that this might be fuel problem, so I changed the fuel filter. Then also changed the EFI relay. the next day I brought it to the dealer to check the fuel pump and regulator. The tech said both are up to specs as far as pressure. Then later that day it happened again, not as drastic as the first time, but it stumbled. Because this is an intermitten problem, the tech said it had to happen when they were driving it for it to be diagnosed. Everybody knows what that means-"leave it here, we'll joy ride when we have a chance between jobs and return it to you with an empty tank and tell you that nothing is wrong".
Does anyone have any other ideas?
Re: engine cut out #102333 11/21/02 11:35 PM
I've had this same problem recently with my 2nd gen. I've found that my negative battery cable comes loose while driving. I replaced the terminal and haven't had any problems since. Hope this solves your prob.
Awesome truck by the way.
Sid
Re: engine cut out #102334 11/21/02 11:44 PM
How tall is that beast?
Re: engine cut out #102335 11/21/02 11:52 PM
Terminals huh? Goood idea, I will check it out. Wouldn't it affect overall electrical though, like stereo, lights, etc. ?
BTW- My runner has 4" suspension, 3" body and torsions cranked just a bit.
Re: engine cut out #102336 11/22/02 12:16 AM
just saw your rig,
very nice,
i like to vacation in maui
is there any spots to go wheelin in hawaii,
i thought next time i was there i would
rent a heep & go exploring,
anyways nice ride
eric
Re: engine cut out #102337 11/22/02 12:30 AM
If that turns out to be the problem, do I win a trip to go and hang out with you? <img border="0" title="" alt="[Big Grin]" src="images/icons/grin.gif" />
And yeah, all my electrical goodies stayed on through the whole thing. I guess it happened so quick that they didn't have time to completely turn off.
Sid
Re: engine cut out #102338 11/22/02 02:49 AM
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by UNLIMITED 96:
<strong>just saw your rig,
very nice,
anyways nice ride
eric</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Thanx for the compliments.
As far a wheeling in Hawaii-places are becomming less and less. I live on Kauai. There are still one or two places you can go, but nothing great like there used to be.
Re: engine cut out #102339 11/22/02 02:57 AM
azrain Offline
Sounds electrical... When you check out the ground (and the positive), make sure everything is nice and clean as well, no corrosion. Check both the battery connections and the termination points as well. I like scotchbrite for this, steel wool can be messy and a pain with those damn metal slivers.
After all that, just kind of poke around a bit and look / tug at all the wiring under the hood. If it's loose, you'll definitely know.
Since I've never been to Hawaii, so I'm not really up to speed, do you have any problems with salt water corrosion or are you a bit more inland? Pardon my ignorance on this one...
Mike
Re: engine cut out #102340 11/22/02 03:18 AM
Nice truck. You keep it clean!
Re: engine cut out #102341 11/22/02 03:27 AM
I agree, nice truck indeed. Umm, why 4.3 Vortec swap when a V8 350 will fit in there too (of course, plus a few minor modifications)?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6271 MB (Peak: 0.7485 MB) Data Comp: Off Server Time: 2026-06-20 18:58:22 UTC
