6G72 education #1080031 02/27/16 11:07 PM
harryo Offline OP
Hello all, new Montero owner & new member.
I bought a 94 montero 6G72 SOHC with very low oil pressure
Thinking rebuild but after engine was removed and inspected
I have decided on a JDM long block. Here's the education question, after searching online for a week I can find plenty of 6G72's SOHC, but all have 6? coils mounted where mine has a distributor other than that the engines look the same. Can someone tell me what changed other than the heads and more importantly can I use one of these: Mitsubishi Pajero Mighty Max Montero Shogun JDM 6G72 SOHC V6 3.0L 24 Valve Engine Second Generation
and what changes will this swap involve?
thank you for your time, harry.
Re: 6G72 education [Re: harryo] #1080035 02/28/16 05:58 PM
In theory yes. Haven't heard of that change over yet, at least I don't recollect one, but using the early heads should set you up.
Re: 6G72 education [Re: Mudraider] #1080038 02/28/16 06:39 PM
Bernoulli Offline
My understanding is that the 24V is not a bolt in conversion. Completely different electrics. Most of the bolt-ons are different as well. It has been done. Starting with a front clip may be the way to go.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: 6G72 education [Re: harryo] #1080047 03/01/16 12:21 AM
Technically, most of those suppliers do no warranty accessories if they are there. They are selling you the longblock. If you had a chance to get every piece on it, and then all the wiring and ECU, it would be very easy to do. The basic engine will be a bolt in.
Re: 6G72 education [Re: harryo] #1080056 03/02/16 04:10 PM
Bernoulli Offline
Double check the oil pressure. These gauges are notoriously unreliable.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6056 MB (Peak: 0.6705 MB) Data Comp: Off Server Time: 2026-10-22 12:16:09 UTC
