Gen 1 3'' Body Lift Questions #1080095 03/09/16 07:17 AM
DJPASS7 Offline OP
I'm wanting to do a 3" BL on my Gen 1 LWB. From what I've read, I haven't seen anyone who has done a 3", only 2". My question is has anyone done a 3" BL and are there any major obstacles aside from the normal obstacles one encounters when doing a 2"?
Thanks,
DJ
1989 Montero LS LWB
Rear LSD, KYB's, 3.0L, Lockup A/T, 2" BL, T-Bar Crank, 33" MTZ's, Full Length Roof Rack, 9k Winch with custom bumper, Rock Sliderz
Re: Gen 1 3'' Body Lift Questions [Re: DJPASS7] #1080099 03/10/16 02:44 AM
My understanding is a lengthening of the shifters is required. Also you will need new hoses. There is enough for 2", but not 3".
Re: Gen 1 3'' Body Lift Questions [Re: DJPASS7] #1080100 03/10/16 05:09 AM
jwthemechanic Offline
For what it is worth here is what I remember from doing a 3" BL my 87 2.6 swb with leafs in rear so yours might be more involved.
I didn't have to lengthen the shifters but did add a custom knob to the t-case shifter for added height.
The radiator or shroud will need to be modified for proper cooling, if you move rad up the hoses might reach. Not sure how involved it will be, I need to do to mine now that the weather is warming.
I extended my fuel filler hose with a section of exhaust pipe, but I believe some people have moved the tank up.
"Turbobitchero" (named by jealous wife) 87 swb base, 89 starion intercooled turbo engine, Bouncy seat, posi in rear, "miller locked" in the front with manual hubs, 3" BL, 305/70/16 bfg's. Sponsored by IAWDLR Racing
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5947 MB (Peak: 0.6487 MB) Data Comp: Off Server Time: 2026-06-20 23:00:52 UTC
