Page 2 of 3 1 2 3
Re: Engine Swap...serious replies please [Re: guzzilapd] #1080190 03/28/16 07:05 PM
gen1v6raider Offline
So, not to change the subject but i can't figure out how to post except from this thread. I am swapping a 6G72 from an 89 model raider into a 91 long wheel LS. The donor motor came from a manual tranny and is going into an automatic. I have about a 1/2" gap between the flywheel and torque converter, ugh. Anyone ever have this problem? Where can i get a crank spacer or do i have to get one made at a machine shop?? help? thanks!!
Re: Engine Swap...serious replies please [Re: gen1v6raider] #1080195 03/28/16 08:51 PM
motero Offline
Fly wheel or flex plate?
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
Re: Engine Swap...serious replies please [Re: motero] #1080196 03/28/16 08:52 PM
flexplate, sorry.
Re: Engine Swap...serious replies please [Re: guzzilapd] #1080197 03/28/16 11:11 PM
You need to go to mitsubishilinks.com and check out the Factory Service Manual for that to see what you are doing.
Re: Engine Swap...serious replies please [Re: guzzilapd] #1080199 03/29/16 01:33 AM
You need the crank spacer off of a 3.0 a/t engine like the one removed from the 91, OR, most any Mopar minivan motor in the junkyard.
Re: Engine Swap...serious replies please [Re: fasteddy] #1080201 03/29/16 02:22 AM
YEP,
i checked the donor motor after realizing all cranks have the same part number regardless of tranny. The spacer was still there! Just couldn't tell from visual inspection. Will have to find new bolts as the old ones were cut down, ugh again. Thanks for your help!
Re: Engine Swap...serious replies please [Re: guzzilapd] #1080203 03/29/16 03:18 AM
Those bolts are single use in my book.
Re: Engine Swap...serious replies please [Re: fasteddy] #1080205 03/29/16 10:08 AM
great to know, which book do you use? Helen, GA rocks! Went to Octoberfest there once back in the late 90's, had an absolute blast. What a beautiful place, got there via the joe brown hwy. thanks for your help again. I'm finally learning my way around this website.
Re: Engine Swap...serious replies please [Re: gen1v6raider] #1080210 03/29/16 07:46 PM
The book in my head that sees tiny little bolts that transfers all the engine power.
Re: Engine Swap...serious replies please [Re: fasteddy] #1080212 03/30/16 01:25 AM
Aha!
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6384 MB (Peak: 0.7467 MB) Data Comp: Off Server Time: 2026-07-09 17:10:43 UTC
