Preemptive head gasket change? What's the vote?! #1080145 03/22/16 06:54 PM
SlimPickins Offline OP
Hey all, I have a 1998 3.5L SOHC Montero with 154k miles (247,830 kilometers) on the clock. She's new to me and seems in decent shape. I'm doing the timing belt/water pump/crank bolt/cam seals and MAYBE the valve guide seals. I'd rather leave the heads on to do this.. The heads don't have too much gunk under the valve covers. I didn't have any overheating issues but only had the truck a couple of months. So... What's the consensus about just doing the head gaskets preemptively? Are they bound to fail eventually or 'if it ain't broke, don't fix it?' What do you guys think?? I really like this truck and hope to keep her for the long haul!
1998 Mitsubishi Montero, winter package, 155k miles, catatonic in the driveway as I get 'er maintenance up-to-date.
Re: Preemptive head gasket change? What's the vote?! [Re: SlimPickins] #1080148 03/23/16 03:26 AM
4x4Wire Offline
If it ain't broke....
As long as you have no indication of head gasket failure, I would opt to leave it along. The other gaskets are more prone to failure or need replacement due to another part failure.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Preemptive head gasket change? What's the vote?! [Re: SlimPickins] #1080152 03/23/16 02:52 PM
Bernoulli Offline
I would opt for preventive maintenance. Don't let it overheat. Three row radiator, alternate temp warning, new hoses, regular cooling system check-ups and maintenance.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: Preemptive head gasket change? What's the vote?! [Re: SlimPickins] #1080155 03/23/16 11:53 PM
I vote for retorque on the head bolts only.
Re: Preemptive head gasket change? What's the vote?! [Re: SlimPickins] #1080163 03/25/16 03:08 AM
Great, thanks guys, will do.
Re: Preemptive head gasket change? What's the vote?! [Re: SlimPickins] #1080184 03/27/16 03:11 AM
I'd go with fasteddy.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6114 MB (Peak: 0.6813 MB) Data Comp: Off Server Time: 2026-10-22 07:41:06 UTC
