Strange white brick thing on Ignition Coil #1080230 04/01/16 10:12 PM
E
ENG1N33R Offline OP
Anyone know what the un-labeled white brick thing is that fastens onto the ignition coil?
Has electrical contacts so it's gotta be doin' something.
I think it's a ballast resistor but the FSM electrical manual only calls it "ignition coil"
Anyone know of a replacement option? OEM or improvised, I care not.
Her Name was Eileen, Because she most often was on a jack...
Re: Strange white brick thing on Ignition Coil [Re: ENG1N33R] #1080234 04/02/16 03:43 AM
You should probly put the year, make, and model
Re: Strange white brick thing on Ignition Coil [Re: ENG1N33R] #1080235 04/02/16 04:05 AM
E
ENG1N33R Offline OP
Gen 1 87 Dodge Raider 2.6L 4G54b + 5 speed KM145
Re: Strange white brick thing on Ignition Coil [Re: ENG1N33R] #1080237 04/02/16 10:44 AM
P
pcc Offline
It's either a capacitor or switch. How is it wired?
A capacitor would absorb some current when the primary collapses. A switch would be controlled by the ECU and turn the coil primary on/off for secondary voltage.
Re: Strange white brick thing on Ignition Coil [Re: ENG1N33R] #1080238 04/02/16 03:25 PM
E
ENG1N33R Offline OP
On the flipside one could prolly figure out the proper wiring that goes all around there. It can get pretty confusing with it all off.
Re: Strange white brick thing on Ignition Coil [Re: ENG1N33R] #1080245 04/03/16 03:02 AM
That's the ballast resistor. Google all it does, but the big thing is that it helps your coil last. You should run it unless you install a coil that specifically says you can do without it.
Re: Strange white brick thing on Ignition Coil [Re: ENG1N33R] #1080250 04/03/16 03:19 AM
It drops the voltage st the coil in ign. run to about 6v. In ign. start the coil voltage is 12v. A stock Starion coil (a tad hotter), or an Accel Super Coil work well. Move the wire on the bottom of the dropping resistor to the coil +. Discard the resistor.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6162 MB (Peak: 0.6908 MB) Data Comp: Off Server Time: 2026-07-14 12:36:52 UTC
