Gen 2 brake upgrade *Edward #1080231 04/01/16 11:50 PM
TOASTY Offline OP
Anyone know if the 315mm rotors and calipers just work or if I need the whole hub assembly and knuckle?
I want to upgrade to the late model Sport brakes (16" wheel equipped trucks)It's time to get all new brakes (all original 215k miles brakes) so I figured I might as well get the bigger stuff. I already have the 1" master cylinder and power booster from said sport.
Re: Gen 2 brake upgrade *Edward [Re: TOASTY] #1080239 04/02/16 04:28 PM
TOASTY Offline OP
Allegedly the rotors backing plate and calipers bolt up, according to the Aussies. I may just buy new rotors and calipers just to see, if i need anything else i'll hit the yards.
Re: Gen 2 brake upgrade *Edward [Re: TOASTY] #1080241 04/02/16 07:09 PM
mynion Offline
should be a cool upgrade, keep us posted =)
94 montero SR 3.5. 33" BFG TA KO's, OME HD rear springs, front T-bar crank.
93 600 Katana. stage 1 jet kit, Uni foam air filter
02 honda shadow. "for when the woman wants to go with"
97 Acura Integra.
Re: Gen 2 brake upgrade *Edward [Re: TOASTY] #1080248 04/03/16 03:10 AM
What year is the ones you're talking about. I have 98 Sport brakes on the 87
Re: Gen 2 brake upgrade *Edward [Re: TOASTY] #1080255 04/03/16 09:55 PM
TOASTY Offline OP
late model Sport, not sure on years but maybe like 01+ or something. Still figuring out Sports, it could be a 3.5 XS thing i'm really not sure.
Re: Gen 2 brake upgrade *Edward [Re: TOASTY] #1080260 04/04/16 03:54 AM
Gotcha. I have a couple in the yards. Nothing that new though.
Re: Gen 2 brake upgrade *Edward [Re: TOASTY] #1080264 04/05/16 01:07 AM
ES_97Sport Offline
Gen 2 Sport.
Monterosportonline.net - Montero Sport Brake Information
I'm not sure what you need to look for to find the 'big brakes'. We've been hashing this out for months on the Sport forum and it appears that they could come on anything from an LS to the Limited in 3.0L or 3.5L.
Re: Gen 2 brake upgrade *Edward [Re: TOASTY] #1080276 04/07/16 01:44 AM
TOASTY Offline OP
I also just discovered the big brakes on my Lexus are the same bolt locations as the Montero. Not that that means anything
Re: Gen 2 brake upgrade *Edward [Re: TOASTY] #1080278 04/07/16 06:20 PM
ES_97Sport Offline
The bolt locations are actually pretty common. There are really only a few 'standard' patterns. AFAIKT its the center hole that changes a lot.
If you can find someone with a machine lathe rotors can sometimes be re-drilled and/or the centers bored out. That's how I get the Exploder rotors on a 6x5.5 pattern. The center is ok but the Ford uses a 5 lug pattern. PITA to find someone who will do it, though. frown
Re: Gen 2 brake upgrade *Edward [Re: TOASTY] #1080300 04/10/16 10:24 PM
TOASTY Offline OP
Interestingly, the big Montero rotors are also quite possibly the same size as the ones on the GX. I wish i could find a confirmed picture of the Montero big caliper.
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6450 MB (Peak: 0.7653 MB) Data Comp: Off Server Time: 2026-10-21 22:05:26 UTC
