3.5L Ground Strap Location #1080261 04/04/16 11:08 PM
ktsdad Offline OP
I rebuilt my 3.5L (1998) and can't remember where the braided ground strap goes. I looked around and one post mentioned running from where the ground wire connects at the A/C compressor up to the block. Any ideas if this is correct? Repair manual is no help.
Frank in AZ
Frank in AZ
Re: 3.5L Ground Strap Location [Re: ktsdad] #1080262 04/05/16 12:48 AM
P
Pop_Clutch Offline
I just had my AC compressor & bracket off twice in the last week.
I've got 2 ground straps on the lower right bolt of the AC compressor bracket. 97 3.5L
Re: 3.5L Ground Strap Location [Re: ktsdad] #1080263 04/05/16 12:59 AM
ES_97Sport Offline
I thought they were the same as the Sport. Two ground straps from the back of the engine to the firewall. - from the post to the fender, fender to the frame, frame to the block behind the compressor.
Re: 3.5L Ground Strap Location [Re: ES_97Sport] #1080266 04/05/16 04:50 AM
ktsdad Offline OP
That makes sense. I had taken a guess and connected it to the motor mount on the frame side (block to body was good to go). Sounds like that may work. I'll double check to see if there is another connection point. That may also solve the extra bolt question I have. smile
Frank in AZ
Re: 3.5L Ground Strap Location [Re: ktsdad] #1080269 04/05/16 05:50 PM
ES_97Sport Offline
I'll check and see if I have the '98 Montero FSMs when I get home tonight and take a quick look at the engine harness when I get home tonight.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6096 MB (Peak: 0.6745 MB) Data Comp: Off Server Time: 2026-06-10 01:49:15 UTC
