Page 1 of 3 1 2 3
New member and Montero Owner Few Questions #1080358 04/20/16 05:58 PM
RMelton Offline OP
Hi guys!! New to the forum and Montero Club.
I have a 1989 Raider with the 3.0L V6. I have a few questions.
I have already swapped the rear coils for GenII for some lift and cranked the torsion bars. I want to remove the rear sway bar and add some longer travel shocks for the rear. I found a thread on a different site that said there was a lot of info about KYB shocks over hear, but I haven't had any luck finding them. Any help would be great. Other manufactures are ok too, but I'm on a budget.
I also want to swap the rear axle for a GenII. I have found a 1992 SR axel at a local salvage yard will it work?
I plan to put an Aussie locker up front. Any feed back from those who have done this. All the threads I have found are pretty old.....
Any ideas for a winch capable front bumper. It looks like ARB was the only choice and they quit making them. I have seen that some have ordered bumpers for other vehicles and modified to fit. Is that my only option???
I will try to add pics if I can figure it out.
Thanks in advance for any help.
1989 Raider SWB 3.0V6
GenII Coils in Rear with T-bar crank up front
31x10.50 SuperSwampers
Re: New member and Montero Owner Few Questions [Re: RMelton] #1080359 04/20/16 08:33 PM
4x4Wire Offline
Welcome to the 4x4Wire TrailTalk forums....
I would like to refer you do some of the resources available on 4x4Wire.
There is a collection of Mitsubishi info in the archives:
http://www.4x4wire.com/mitsubishi/
The Search feature at the top is customized to look at 4x4Wire archives and the forum archives to return results posted on 4x4Wire.
Axle swaps have been a common discussion in the forums. There is a lot of info available.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: New member and Montero Owner Few Questions [Re: RMelton] #1080367 04/22/16 04:39 PM
92 SR. Did that have an air locker rear axle? If it doesn't have a locker, I wouldn't waste my time.
Re: New member and Montero Owner Few Questions [Re: RMelton] #1080370 04/22/16 09:05 PM
RMelton Offline OP
The 92 has a locker, but I have been told that the gear ratios in the 92 are different. I need a 95-96 for matching gear ratios.
Re: New member and Montero Owner Few Questions [Re: RMelton] #1080372 04/22/16 11:31 PM
Gen I Montero / Raider will most likely have 4.625 gears. The early Gen II also shares this ratio, but you don't get the air locker, only LSD. The middle year Gen IIs had 4.636 gears, not enough difference to be a problem, swap away!
Re: New member and Montero Owner Few Questions [Re: rxinhed] #1080373 04/22/16 11:33 PM
Also, you can use a Warn winch mount blank, create your own bumper or none. Most of 'the Guys' have made their own for the last decade I've been here.
Re: New member and Montero Owner Few Questions [Re: RMelton] #1080376 04/23/16 12:06 PM
The early SR info sure is spotty. What different gears did they have?
Re: New member and Montero Owner Few Questions [Re: RMelton] #1080387 04/23/16 09:48 PM
4.625 (Early)
4.636 (Later)
4.90 (Some, but can be sourced from same era Montero Sports)
5.29 (Elsewhere)
Re: New member and Montero Owner Few Questions [Re: RMelton] #1080388 04/24/16 04:50 AM
I sure wo u ld lke to try out some 5.29 with some Aussie crawler gears
Re: New member and Montero Owner Few Questions [Re: Mudraider] #1080394 04/25/16 01:10 AM
Dan will let you know how cool they are.
Had I the scratch and drive and need, I probably should have purchased the 5.86 4-cyl only gears those many years ago.
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6448 MB (Peak: 0.7651 MB) Data Comp: Off Server Time: 2026-11-03 04:52:59 UTC
