ir Plenum #1080630 05/11/16 06:53 PM
KB2IAW Offline OP
I Am About To Try The Air Plenum Mod , and stabilize the intake valves in the open position ...
So What i really want to know ...Are There any recent up dates ,or results on this change ..it`s a 1994 montero3.5 sr
179.000 miles still running strong except for the intake air plenum issue ??? any one ???
1994 montero SR 3.5 v6
City Of Hills Oneonta N.Y. FREEDOM HAS A TASTE,AND FOR THOSE THAT HAVE FOUGHT FOR IT, THE TASTE IS SO SWEET , THE PROTECTED WILL NEVER KNOW .
VENI VEDI DECI <oneontasportsmenclub.net>
Re: ir Plenum [Re: KB2IAW] #1101293 05/19/16 12:23 AM
ryany Offline
The results are that you will loose low end torque by fixing the variable intake butterflies in the open position.
What are you hoping to accomplish by fixing it in the open position? If the shaft bushings are worn to where the shaft has any slop in it, the butterflies will still be able to work loose and be swallowed by the engine regardless of whether they are open or closed.
95 Montero SR
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.5876 MB (Peak: 0.6358 MB) Data Comp: Off Server Time: 2026-10-21 20:44:48 UTC
