Engine swap? #1082408 11/22/05 07:44 AM
Can anyone tell me what all is envolved or (even if it is possible)to replace my 2.4 in my 1994 nissan 4x4 with a 3.0 v6. Thanks <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Engine swap? #1082409 11/24/05 04:10 PM
It's possib;e, but actually moretime consuming and more expensive than swapping in the following engines:
Ford 302: This V8 fits nicely in our engine bay. Motor mounts and egverything need to be fabbed from scratch.
Chevy 4.3 TBI and 4.3 Vortec V-6: Aftermarket motormounts are avaiable. Easiest of the swaps, and get to keep Fuel Injection. Best $$ to power-to weight ratios. Biggest bang for the buck!
Buick 3.8: Smallish for a Nissan Hardbody, and no Fuel Injection (though it can be upgraded), but still more power than our 2.4
I'm keeping my little 4-popper (at least for now), and running dual cases and 5.14 gears in the axles. I'll still be underpowered for 40" tires, but I'll also be less likely to break any drivetrain parts.
Re: Engine swap? #1082410 12/04/05 06:37 AM
How about this....What is envolved with installing a 1988 Z24 dual plug engine in my 1994 nissan 4x4? [color:"orange"] [/color] <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Engine swap? #1082411 12/06/05 03:01 AM
Why would you want to downgrade? The Dual spark/cylinder on the Z24i (fuel injected Z24) was meant for power. It was for emmisions! The KA24E (MFI) puts out more power and torque than the Z24 (carb) or Z24i (TBI).
Re: Engine swap? #1082412 12/06/05 07:59 AM
Can I put the fuel injected head from the 1994 on the 1988 Z24 block? <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Engine swap? #1082413 12/09/05 05:44 PM
The blocks are similar, but I've never tried swapping heads (though I have KA24E in my '93, and a Z24i in my '89 parts truck). I would try it on two scrap engines first. If the KA24E distributer will bolt into the Z24 block, then I don't see why it shouldn't work. I know the whole Z24 series interchanges (Z24 and Z24i), but the KA24E was a whole new redesign (the trannies bolt up from '86.5 thru '96.5, just use the starter that goes with the engine--there are 4 different starters available for the 4 cyl!). So, will a KA24E head, bolt to a Z24 (carb) block? Maybe. Will a Z24i head bolt to a Z24 block? 99% sure, yes.
Re: Engine swap? #1082414 12/13/05 09:01 PM
SMITHTONU02 Offline
THE 3.0 NISSAN V6 IS NOT MUCH MORE POWERFUL THAN THE 4CYL NISSAN ENGINE IF AT ALL......TRY REMOVING THE INTAKE HOSE AND AIR BOX, YOU WOULD BE SUPRISED AT THE DIFFERENCE.
Re: Engine swap? [Re: SMITHTONU02] #1082415 03/04/06 10:08 AM
Re: Engine swap? #1082416 03/10/06 08:57 AM
Baldy Offline
I know this not a Nissan truck but this might give you some ideas. I swapped in a 1991 Chevy 350 small block into my 82 Dodge D50 4x4. What an amazing increase in power and torque. Trouble is I started breaking axles so I had to swap them out for a Dana 44 up front and a Chevy 12 bolt in the rear. Here are some pics [Linked Image] [Linked Image] [Linked Image]
Re: Engine swap? [Re: Baldy] #1082417 03/12/06 06:07 PM
350s don't fit too well under Nissan hoods (not with stock grills anyway). The radiator won't fit (some pricey custom radiotors squeeze in, still w/no room for a mech. fan though). Ford V8s fit the best under Nissan hoods (302s and 351s). The 4.3 Chevy V-6 also fits nicely.
Moderated by  4x4Wire, Dandeman, Mike Bondi
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6136 MB (Peak: 0.7038 MB) Data Comp: Off Server Time: 2026-07-14 10:50:32 UTC
