RATTLING 4CYL. WHEN STARTED #1082418 12/14/05 08:42 PM
SMITHTONU02 Offline OP
MY 97 HARDBODY 4CYL RATTLES LIKE CRAZY AFTER IS STARTED. IT SOUNDS LIKE A BEARING OF SOME SORT, BUT RECENTLY I HAVE REPLACED THE ALTERNATOR AND CHECKED ALL OF THE PULLEYS FOR WORN BEARINGS. WHAT COULD BE CAUSING THIS???? IT USUALLY GOES AWAY AFTER A WHILE.
Re: RATTLING 4CYL. WHEN STARTED [Re: SMITHTONU02] #1082419 12/19/05 04:15 PM
man i reckon u cant get a response in the Nissan forum <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: RATTLING 4CYL. WHEN STARTED [Re: SMITHTONU02] #1082420 12/25/05 04:05 AM
Sorry for the late response...I don't check this forum much anymore.
Did you check the clutch fan? Have you tried to pinpoint where the noise is coming from? That would help some...otherwise, it's kinda difficult to sugest what your problem might be.
MickB
Re: RATTLING 4CYL. WHEN STARTED #1082421 12/27/05 04:02 AM
Without knowing where this noise is coming from, it could also be as simple as a loose/rattling exhaust heat sheild.
MickB
Moderated by  4x4Wire, Dandeman, Mike Bondi
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5932 MB (Peak: 0.6527 MB) Data Comp: Off Server Time: 2026-07-14 10:50:52 UTC
