RATTLING 4CYL. WHEN STARTED
#1082418
12/14/05 08:42 PM
MY 97 HARDBODY 4CYL RATTLES LIKE CRAZY AFTER IS STARTED. IT SOUNDS LIKE A BEARING OF SOME SORT, BUT RECENTLY I HAVE REPLACED THE ALTERNATOR AND CHECKED ALL OF THE PULLEYS FOR WORN BEARINGS. WHAT COULD BE CAUSING THIS???? IT USUALLY GOES AWAY AFTER A WHILE.
Re: RATTLING 4CYL. WHEN STARTED
[Re: SMITHTONU02]
#1082419
12/19/05 04:15 PM
man i reckon u cant get a response in the Nissan forum <img src="/forums/images/graemlins/confused.gif" alt="" />
[Re: SMITHTONU02]
#1082420
12/25/05 04:05 AM
Sorry for the late response...I don't check this forum much anymore.
Did you check the clutch fan? Have you tried to pinpoint where the noise is coming from? That would help some...otherwise, it's kinda difficult to sugest what your problem might be.
MickB
#1082421
12/27/05 04:02 AM
Without knowing where this noise is coming from, it could also be as simple as a loose/rattling exhaust heat sheild.
MickB
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.007s) Memory: 0.5927 MB (Peak: 0.6522 MB) Data Comp: Off Server Time: 2026-07-14 10:49:52 UTCValid HTML 5 and Valid CSS
