CV Boot Leaking - Again #103976 12/04/02 03:32 AM
N
NJ Offline OP
Sorry to be "flogging a dead horse" but there were some questions asked in this old trailtalk thread that I still have not found answers to.
Since my SAW install I have noticed that my inner CV boot is leaking on the small side/shaft end and I was wondering... <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
(1) Are the OEM clamps "user servicable" I cant see any easy way to tighten them.
(2) If using a stainless steel hose type clamp, will that not put the whole thing out of balance due to the tightening nut.
(3) If I replace with a zip tie can that really get the boot tight enough. Even a mechanic I know says he uses zip ties, anyone here have any objections to zip ties.
Thanx
1996 Hilux Surf KZN185, 3.0L 1KZ-TE Turbo Diesel, 5-Speed
BFG AT's 265 70R16, SAW's, 2.5 Cornfed & OME N86C shocks, Sway Bars Removed, Rear Diffbreather.Webshots Pictures
Re: CV Boot Leaking - Again #103977 12/04/02 04:08 AM
Don't use hose clamps that cost me 400 bucks and cut up perfectly good boots.
Re: CV Boot Leaking - Again #103978 12/04/02 07:40 AM
Mojo_Risin Offline
Well, for every yin there is a yang- I posted on that old thread (almost a year ago now) And I used the metal hose clamps (back then) and I have had no more leaking grease and no cut boots. I guess you have to be cautious not to tighten them too tight to cut into the boot but tighten them enough to clamp harder then the stock clips (which are metal as well)
Personally I think it would be hard to get a zip tie that tight - but you might try that before the metal ones. I guess you could always wrap the metal clamps in duct tape or something to reduce the sharpness of the metal edge of the hose clamp.
Mojo
Re: CV Boot Leaking - Again #103979 12/04/02 05:17 PM
I haven't had any problems with using metal hose clamps either. It certainly doesn't throw the CV out of balance at all, at least not noticably.
Konaman
Re: CV Boot Leaking - Again #103980 12/05/02 04:49 AM
N
NJ Offline OP
Thanks guys, I was more concerned about the balance/vibration issue.
PHP: 7.4.33 Page Time: 0.008s Queries: 14 (0.005s) Memory: 0.6008 MB (Peak: 0.6631 MB) Data Comp: Off Server Time: 2026-06-22 11:18:55 UTC
