Page 2 of 3 1 2 3
Re: Mystery Coolant Leak.... [Re: pcc] #1101318 05/20/16 11:02 PM
P
pcc Offline
OK, I just ordered some UV dye from Amazon. I have a light and glasses from my UV dye for my A/C system.
I'll drive it some more and hope it starts to leak again.
Re: Mystery Coolant Leak.... [Re: fasteddy] #1101321 05/21/16 10:34 AM
cheesegrater Offline
The intake manifold and head are bolted together with a gasket in between. Coolant runs through there. A leak can develop at that connection.
Re: Mystery Coolant Leak.... [Re: cheesegrater] #1101322 05/21/16 03:14 PM
P
pcc Offline
There is no indication coolant is getting into the intake. I can see the top of the intake/head connection and nothing. But since I have not identified where the leak is I can't discount anything.
Re: Mystery Coolant Leak.... [Re: cheesegrater] #1101323 05/21/16 08:06 PM
P
pcc Offline
I looked at my FSM and yes it shows a coolant connection front PS as you state. So yes that could be a possibility where no coolant would get into the intake. My intake gaskets are original, I've ordered all parts for TB service including the intake gaskets.
Dye to be installed tomorrow.
Re: Mystery Coolant Leak.... [Re: pcc] #1101328 05/22/16 05:19 PM
BottomFeeder Offline
There are some rubber coolant lines under the intake manifold and plenum. Check those as well. It will dribble down the motor and make it look like something else is leaking.
1990 Montero LS "Bottom Feeder" LWB, 33's, Cheapass Lift, 2" body lift, Dual BoUnCyS, Dual LSD's, KC's.
1995 Montero SR Complete LS interior swap and a BoUnCy from a 96 SR. General Grabber AT2's 33X12.5. 1.5" Body Lift
Re: Mystery Coolant Leak.... [Re: pcc] #1101329 05/22/16 08:08 PM
P
pcc Offline
I installed the dye (wear gloves), will run it this week and hope to see leak.
I can see where the lower manifold bolts to the PS head. No sign of leak there.
I ordered all the parts for the TB work as well as lower intake gaskets in case I need to replace.
Re: Mystery Coolant Leak.... [Re: Dylan] #1101334 05/23/16 01:17 PM
Dylan Offline OP
I appreciate all the input so far. I'm not sure who has or has not seen the images I posted, but in my case it seems like I've got a great idea of where the water is coming from. I just have no idea what it is. Up around the head gasket an inch or two higher, it's completely dry. Up under the intake, also dry. It's only wet from whatever is attached to the block right there just above the top of the bracket that holds the oil filter. Any idea what that piece of metal is and what's behind it?
'95 Montero SR 3.5L, Trail Gear Sliders, Rugged Ridge XHD Front Bumper, 33x12.5 Duratracs, much more in the works....
Re: Mystery Coolant Leak.... [Re: Dylan] #1101335 05/23/16 03:45 PM
Radiator pressure test. It pressurizes the whole cooling system...
Re: Mystery Coolant Leak.... [Re: fasteddy] #1101336 05/23/16 07:42 PM
P
pcc Offline
I think with myself and Dylan is we can't see the starting point leak with all the stuff in the way. Pulling the engine front apart with water pump means we can't use pressure to activate the leak.
I'm hoping the dye will show me where.
Re: Mystery Coolant Leak.... [Re: fasteddy] #1101338 05/24/16 01:47 AM
Dylan Offline OP
I get that it does... what I am saying is I can see the leak, I just don't know what is there or why it should be leaking. It leaks just by filling the radiator so I don't think putting pressure on it will be possible, much less tell me anything new...
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.005s) Memory: 0.6375 MB (Peak: 0.7617 MB) Data Comp: Off Server Time: 2026-10-21 19:37:54 UTC
