Page 3 of 3 1 2 3
Re: Mystery Coolant Leak.... [Re: Dylan] #1101339 05/24/16 02:35 AM
4x4Wire Offline
In theory the pressure test will force air out the leak. That air will create bubbles to help pinpoint the leak....
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Mystery Coolant Leak.... [Re: Dylan] #1101344 05/24/16 12:10 PM
P
pcc Offline
Originally Posted by Dylan
[quote=fasteddy]It leaks just by filling the radiator so I don't think putting pressure on it will be possible, much less tell me anything new...
Yes, my leak also is non-pressure leak. Just can't follow the wet trail high enough to see source because of all the metal parts in the way.
I'm going to run the dye a couple weeks then do a TB tear down. Will report when I find something useful.
Re: Mystery Coolant Leak.... [Re: pcc] #1101383 05/27/16 12:45 AM
P
pcc Offline
Got a good dye trace, no UV required. Leak definitely not from frost plug, but higher up. Will not know specifically until I do the TB tear down in a week or two.
Re: Mystery Coolant Leak.... [Re: pcc] #1101431 06/02/16 09:12 PM
P
pcc Offline
Today I got around to tearing into the engine for the leak and TB service.
From the pictures it looks like the leak is from the passenger side water pump connection. Nothing higher and no indication of freeze plug leak.
[Linked Image]]
[Linked Image]]
[Linked Image]]
Re: Mystery Coolant Leak.... [Re: Dylan] #1101432 06/02/16 10:36 PM
That's a good sign.
Re: Mystery Coolant Leak.... [Re: Dylan] #1101438 06/04/16 02:06 AM
mynion Offline
this was what I was thinking it might be coming from, looks like you found the same thing.[Linked Image]
94 montero SR 3.5. 33" BFG TA KO's, OME HD rear springs, front T-bar crank.
93 600 Katana. stage 1 jet kit, Uni foam air filter
02 honda shadow. "for when the woman wants to go with"
97 Acura Integra.
Re: Mystery Coolant Leak.... [Re: Dylan] #1101551 06/19/16 06:59 PM
P
pcc Offline
but for the life of me, I can't understand what is going on. Someone please enlighten me...
OK, so I'm with Dylan on this one. I also did a timing belt/water pump tear down with all new gaskets and thought (see other posts and pics) that the leak was from the water pump where it is gasket'd on to the block, even the dye showed that.
Today I started the truck and low and behold same leak same spot.
So I'm done tearing this engine apart, bought some "Blue Devil" block stop leak and it seems to have fixed the leak. Saved for now, will follow-up if any changes.
Re: Mystery Coolant Leak.... [Re: pcc] #1101574 06/24/16 10:45 AM
P
pcc Offline
The Blue Devil has fixed the leak. Blue Devil claims a "permanent" fix and no need to keep the leak stop in the system after the leak stops. I have flushed the system and put in new A/F. Leak has not come back.
I will monitor this but so far I can attest to Blue Devil working. This saved me a ton of extra work.
Re: Mystery Coolant Leak.... [Re: Dylan] #1101575 06/24/16 02:17 PM
4x4Wire Offline
Thanks for the update. A number of the older leak stop solutions are noted for clogging radiator coils. Hope the "permanent" is not just advertising hype...
John Stewart
Editor - 4x4Voice
Re: Mystery Coolant Leak.... [Re: pcc] #1103068 02/19/17 11:17 PM
P
pcc Offline
Brought this back for further update.
The Blue Devil did not hold. I have just torn this down once again. It now looks like the water pump shaft seal failed, nothing the BD could have fixed. It got to be so extreme I could not drive it. The weep hole takes leak to the same spot on the PS of the engine. I now believe this was the original leak and the second one.
I also developed an intake leak which I thought was a leak from the intake plenum. After teardown it is not there but from the new head gasket I needed at the last TB service where I needed to take the head off to retrieve the valve dropped inside doing the valve seals.
This is the last attempt to repair this engine. I have a rebuilt WP to place the leaky one and I'm going to try the Blue Devil head gasket sealer. If this does not work the truck will be up for sale. I've no time or patience to tear it down again. 25 years of use is pretty good.
It'll make a good project or parts truck.
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6392 MB (Peak: 0.7654 MB) Data Comp: Off Server Time: 2026-07-13 06:37:42 UTC
