Re: Advice for a first time Montero SR Owner [Re: MMeadows] #1101824 07/25/16 05:29 AM
Mitsubishi Links FSM
You looked through the entire FSM. Firing order will likely be in the introductory chapter. Based upon the bolt diameter, the torque specs are listed there, too. Also, anything electrical is discussed in the Electrical FSM, not the Chassis book (Engine, Trans, Body). We are not who made this so, but the navigation is simple enough.
Re: Advice for a first time Montero SR Owner [Re: MMeadows] #1101825 07/25/16 05:36 AM
And, yes, the Mitsubishi engines were used simultaneously in many platforms. You're unknown bolt hole may be for a commercial application like a forklift or boat, a fwd application in a car model.
Part of your learning about the Mysterybishi is the zen you feel afterward. Having looked at the tasks you performed in 6 hours, I'd not scoff at that. Lots of things to keep track of and separate; but, I wouldn't knock this board or the history that it holds in your frustration. As a long time guy here, but not as long as others, I can pass along the lesson of patience, grasshopper.
The sorting of your no start is just for another day.
Re: Advice for a first time Montero SR Owner [Re: rxinhed] #1101828 07/25/16 08:29 PM
MMeadows Offline OP
Last thing i want to do is bite the hand that feeds me smile. I didn't mean to come across as putting this board down. just pointing out that the sticky link is broken before some says " the FSM is online"
Here is why I am struggling. I have 97 montero SR so it has the 3.5 SOHC engine that they only used for a couple years. The link you listed is for the 96 dohc 3.5.
If you look at the picture i posted you will see that is my engine but it is labeled wrong "6G74 2001 model" the car was made in 97 although i believe it would have a 6g74a in it, and is a montero not pajero. But this is my engine for sure. All the other pictures in the FSM could not be my motor. So part of my frustration is i cant find simple information like "firing order" because i either cant read or things are labeled incorrectly.
That is crazy to me that Mitsubishi considers mechanical and electrical separate functions of service, i will give them a tip of the hat by having all wiring harness connectors color coded and unique fittings for each connect.
When i get home im going to check and see if there are any grounds i forgot to connect or put in the right place. Like i said the FSM skips over the 20+ brackets and ground connections, hose fitting etc that needed to be disconnected but you only know that when you try to pick up the plenum and its stuck...
Also thank you for the motivation, i shouldn't scoff at the work i did or the money i saved while still using quality parts, i was just feeling low last night as my car was working before i tried this, and now its not.
97 Montero SR: 2in body lift. 33" KM2
Re: Advice for a first time Montero SR Owner [Re: MMeadows] #1101830 07/26/16 01:08 AM
MMeadows Offline OP
my front wheel drive lights are blinking non stop now. I think this is a sign of a vacuum leak or a broke a sensor. Either way I have not put the car back together right. Can any one take a picture of there 3.5l sohc engine with the plenum cover removed and send it to me. I dont think i will find a firing order or vacumm diagram online.
I think the 3.5l SOHC was in the 1997-2000 but im not positive
Re: Advice for a first time Montero SR Owner [Re: MMeadows] #1101835 07/26/16 09:08 PM
MMeadows Offline OP
So I was able to find the firing order and I had it on correctly. The reason for the non start and the blinking front wheel drive lights was due to my main wire harness connector not being clipped in all the way. Was able to click that back in and it started right up. Overall very happy I went with o.e.m. Parts as they were different than what I pulled out of the car. Not sure if the Mitsubishi pcv was necessary though. Going to order parts for the timing belt next. Looking at 600 for everything.
Re: Advice for a first time Montero SR Owner [Re: rxinhed] #1102204 10/06/16 02:59 AM
O
Omardottcom Offline
Dang It!!!!!..... I was so excited I had bought the Factory Service Manual in PDF format off of someone on eBay las week for $15. It's the same damn manual that RXinhed just provided the link for to download for free!!!! SMH I just got served.
Owner of 1995 Mitsubishi Montero
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6218 MB (Peak: 0.7265 MB) Data Comp: Off Server Time: 2026-05-29 16:10:53 UTC
