At the scrap yard.. Need some info ASAP please #1101526 06/16/16 04:05 PM
N
nandomart Offline OP
Im at the pick and pull and found an 89 v6 manual montero. It has the lsd coil sprung axle. I have an 89 dodge raider swb leaf sprung axle. Can i use the lsd third member on my axle or do I need to take the whole axle and connvert mine to coil sprung. How about the front axle? Ive read that there is a locker available for the v6 front diff?
Re: At the scrap yard.. Need some info ASAP please [Re: nandomart] #1101527 06/16/16 04:47 PM
F
fhuzz Offline
I'm inclined to believe that the 3rd member is not interchangeable between a v6 and 4cyl.
'89 Monty LWB auto, 3rd row seating, 95SR rear + coils, genII UCA's and calipers/rotors, dual bouncies.
Re: At the scrap yard.. Need some info ASAP please [Re: nandomart] #1101535 06/17/16 01:01 AM
N
Any thing worth salvaging? Front dif worth the work?
Re: At the scrap yard.. Need some info ASAP please [Re: nandomart] #1101536 06/17/16 02:48 AM
If you salvage the front axle, you can use a Starion LSD or Aussie locker. The V6 manual CVs are reportedly the strongest of the breed. Is this SWB or LWB? Some of the SWB parts are unique and valuable.
Re: At the scrap yard.. Need some info ASAP please [Re: nandomart] #1101539 06/17/16 04:23 AM
BottomFeeder Offline
I is my understanding that 89 Raiders and Monteros were coil sprung. SWB and LWB
1990 Montero LS "Bottom Feeder" LWB, 33's, Cheapass Lift, 2" body lift, Dual BoUnCyS, Dual LSD's, KC's.
1995 Montero SR Complete LS interior swap and a BoUnCy from a 96 SR. General Grabber AT2's 33X12.5. 1.5" Body Lift
Re: At the scrap yard.. Need some info ASAP please [Re: BottomFeeder] #1101540 06/17/16 04:24 AM
Could you still get a 4 cylinder in 89?
Re: At the scrap yard.. Need some info ASAP please [Re: nandomart] #1101548 06/19/16 12:59 AM
1989 was last year for both 2.6L and leaf springs in USDM. I have parted one 2/89 Montero 4-cyl.
Re: At the scrap yard.. Need some info ASAP please [Re: nandomart] #1101549 06/19/16 01:02 AM
1989 was last year for both 2.6L and leaf springs in USDM. I have parted one 2/89 Montero 4-cyl. All V6 models were coil.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.004s) Memory: 0.6264 MB (Peak: 0.7051 MB) Data Comp: Off Server Time: 2026-05-26 04:58:16 UTC
