Overdrive solenoid for 1990 LWB 3.0L #1101731 07/10/16 07:43 PM
JAVYPRO Offline OP
Well, had the rear main engine seal installed together with the oil pan gasket, now the tranny will not shift into 4th. Jacob, the mechanic determined that the removal of the tranny caused the overdrive solenoid to get damaged in the process.
The solenoid part number: MR111917 old/ MD609445 new.
I am having a bit of a hard time locating one. Found that www.lovemitsubishiparts.com might have it but have to wait till Monday.
In the meantime I keep searching the web.
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Overdrive solenoid for 1990 LWB 3.0L [Re: JAVYPRO] #1101733 07/10/16 09:33 PM
Try taking it to a Toy or Jeep dealer for an eyeball match to what goes on the Aisin Warner version they use. Toy late 80's 4runner pickup had one for sure. Many 6cyl and v8 heeps. Try an interchange parts search on car-part.com and use 87 to 91 montero raider.
Re: Overdrive solenoid for 1990 LWB 3.0L [Re: JAVYPRO] #1101739 07/11/16 02:46 AM
JAVYPRO Offline OP
Thanks Eddy,
I went to Rockauto and they have a the control solenoid and they call it for the KM148-6 or AW372L.
As per the description from Rockauto:
ATP NE16
FitsAutomatic trans.; Trans. code AW372L; 3 ohm PWM Lock-up
OrAutomatic trans.; Trans. code KM148-6; 3 ohm PWM Lock-up
and
ATP NE18
FitsAutomatic trans.; Trans. code AW372L; 3 ohm EPC, PWM Lock-up
OrAutomatic trans.; Trans. code KM148-6; 3 ohm EPC, PWM Lock-up
What is the difference between EPC and non EPC? everything looks the same as well as the vehicles list that can use the part.
My tranny plate ID says I have a V4AW2
Javy
Re: Overdrive solenoid for 1990 LWB 3.0L [Re: JAVYPRO] #1101744 07/11/16 01:43 PM
JAVYPRO Offline OP
According to Roadkill customs I found the is:
Model
MITSUBISHI MONTERO 2.6L L4 - 3.0L V6 (4X4)
Years: 1990-5/94
Transmission: AW372L (A44DL)
Model: MITSUBISHI VAN/WAGON 2.4L L4
Years: 1987-90
Still it doesn't answer my question on the EPC and non-EPC solenoid model.
Read more: Transmission Cross Reference Database: AW372L (A44DL) http://www.roadkillcustoms.com/hot-...ference-Database.asp?Transmission=AW372L (A44DL)#ixzz4E6fH2WRf
Javy
Re: Overdrive solenoid for 1990 LWB 3.0L [Re: JAVYPRO] #1101745 07/11/16 03:26 PM
JAVYPRO Offline OP
Guys, the part is obsolete from Mitsubishi. Will have to hit the local yards and these are kind of hard to find at the local Atlanta yards.
There are two 1997 GEN IIs 3.5L but I am not sure it will be the same as these might be computer controlled.
If any of you come across one please let me know.
Javy
Re: Overdrive solenoid for 1990 LWB 3.0L [Re: JAVYPRO] #1101757 07/13/16 02:57 AM
Will do. Going g to the yard tomorrow
Re: Overdrive solenoid for 1990 LWB 3.0L [Re: JAVYPRO] #1101764 07/13/16 01:42 PM
JAVYPRO Offline OP
Thanks man.
Javy
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6183 MB (Peak: 0.7097 MB) Data Comp: Off Server Time: 2026-07-09 13:23:15 UTC
