Gen 1 Rear crossmember #1101905 08/16/16 03:56 PM
E
ENG1N33R Offline OP
Just took off the bumper to get a better look at the ate up crossmember. I hasn't spread to the frame rails yet, only a milimeter or 2 of surface rust.
Can it be saved or do I need to track down another Gen 1?
I am willing and able to drop the serious coin on getting it fixed right and good, Ideally I want to be able to tow when I move west to Oregon. I do not expect to pay less then $1000 for a quality fabricator to fix up the back end amongst having a few other welding things done.
Her Name was Eileen, Because she most often was on a jack...
Re: Gen 1 Rear crossmember [Re: ENG1N33R] #1101916 08/20/16 01:09 AM
Contact Jim Napiorowski (MI_Mitsu) or the AZ Crew. To my knowledge, these are the only guys here actively parting Monteros. Also, the SWB V6 models share this piece.
Re: Gen 1 Rear crossmember [Re: ENG1N33R] #1101925 08/21/16 12:23 AM
That should be a relatively simple piece for a competent fabricator to make.
Re: Gen 1 Rear crossmember [Re: ENG1N33R] #1101930 08/22/16 11:48 PM
Fabricating a new remember crossmember is no big deal, i can almost guarantee that the next crossmember is in equal shape. Also check the area on the frame rail between the two, however if you're coming to the west coast I recommend stopping in Az and picking up a new completely rust free Montero. I can have one here for you in ANY trim, ANY engine and ANY transmission. Think about it.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6026 MB (Peak: 0.6589 MB) Data Comp: Off Server Time: 2026-07-14 12:37:18 UTC
