What can cause inside of rear tires to wear fast? #1102041 09/09/16 02:23 AM
W
wilde Offline OP
2001 Montero XLS (full size, about 165,000 miles). Rear tires wearing faster on inside. About the first 2", and it is very noticeable now. Can this cause be anything other than alignment problems? I heard it could be the "camber" adjustment. I'm not sure how it would be thrown out of wack though. It seems the driverside - rear is a little worse, but I'm not sure..left and right are pretty close. Can this be adjusted at home, like DIY style? I think I see it sagging a little (as if its sagging in middle) when I look at it from behind...
Re: What can cause inside of rear tires to wear fast? [Re: wilde] #1102042 09/09/16 10:03 AM
cheesegrater Offline
I believe your vehicle has independent front and rear suspension. A quick look tells me there can be toe in/out issues with the rear wheels. Better have it checked at an alignment center.
Re: What can cause inside of rear tires to wear fast? [Re: wilde] #1102046 09/10/16 02:32 PM
Exactly ^^^^^ Check it out in the FSM for you vehicle at mitsubishilinks.com
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5899 MB (Peak: 0.6435 MB) Data Comp: Off Server Time: 2026-07-10 17:01:31 UTC
