All alignment bolts seized...need suggestions for #1102111 09/21/16 09:06 PM
W
wilde Offline OP
Howdy. I have a 2001 Montero XLS and all the adjustment bolts are completely frozen and won't allow me to adjust anything. The tow and camber are way off for rear tires (eating inside edge badly on both rears) and toe is slightly off for the front (slight uneven wear on outside fronts). I took it to a Honda dealer (no Mitz near me) to try adjustment and they too were not able to adjust them with a 4' breaker bar and impact wrench. Took it in for 4-wheel alignment and they tried for an hour but couldn't do it. Their suggestion was to cut them off, maybe even some drilling.
Any suggestions how to break the seized adjustment bolts? I can loosen all of the locking nuts on opposite ends of the bolts, but the bolt themselves that do the tuning are the problem. Weird, because the rust isn't bad on this Montero.
Re: All alignment bolts seized...need suggestions for [Re: wilde] #1102113 09/21/16 11:27 PM
4x4Wire Offline
Personally, I like this:
http://www.kanolabs.com
There is also a product called PB Blaster that is well liked....
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: All alignment bolts seized...need suggestions for [Re: wilde] #1102182 10/03/16 05:41 AM
Oso Offline
Acetone and ATF mixed 50/50. Nothing better. Brush it on, let it sit for a bit and tap lightly with a hammer. Apply more and let it sit. Repeat the process. It's never failed.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.5950 MB (Peak: 0.6489 MB) Data Comp: Off Server Time: 2026-10-22 12:16:09 UTC
