Radiator for '90 Montero? #1102290 10/18/16 04:28 AM
nvmonty Offline OP
I've been trying to find a new radiator for a '90 Monty. Various parts vendors list a model 1384 for the '89 to '91 V6's but they don't fit my '90-- neither the mounting holes for the frame nor the bolt holes for the fan shroud line up correctly. Has anyone found a source that fits? confused
90 LWB RS: 3 L/mt, JBaker springs, bushings, swaybars. KYB shocks tweaked, 134k mi, original owner.
97 LWB SR: SOLD Sep. 2014 131,006 mi: running boards removed, BFG 31x10.5 AT/KO tires, Air locker, AirLifts, KYB shocks, Cibie fogs, 3rd owner.
Re: Radiator for '90 Montero? [Re: nvmonty] #1102294 10/18/16 09:23 PM
nvmonty Offline OP
I'm running out of options for a #1384 radiator to fit the '90 Monty. Nobody seems to have one in stock. Can anyone provide the dimensions for a #1504 radiator on a GEN II 92+ radiator to see if it could be made to fit?
In particular, I would need the horizontal distance between the side bracket mounting holes on the front side. For my '90 this is 25 1/8 inches. If the front brackets fit I can make the fan housing fit on the rear side.
Thanks!
Re: Radiator for '90 Montero? [Re: nvmonty] #1102298 10/19/16 12:42 AM
Have a radiator shop rod yours out. Or, have Gen I 4-cyl radiator 3-core guts put in your V6 tanks.
Gen II radiator is laid out differently.
Re: Radiator for '90 Montero? [Re: rxinhed] #1102300 10/19/16 03:05 AM
nvmonty Offline OP
The existing radiator on the '90 Monty is trashed-cannot be repaired.
Looks like the GEN II '92 + core width is the same. If the horizontal distance between the frame mounting holes is the same as the '90, 25 1/8 inches, I can make a GEN II radiator work. The hose connections are in the same places.
Re: Radiator for '90 Montero? [Re: nvmonty] #1102312 10/21/16 01:25 AM
Even if it's wider, you could riv-nut it in.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6093 MB (Peak: 0.6746 MB) Data Comp: Off Server Time: 2026-05-26 04:56:39 UTC
