Head gaskets, what else? #1102484 11/21/16 05:43 AM
marksroberts61 Offline OP
I just picked up a 95 SR with a bad head gasket, 167k, while I'm in there, I figured I'd do a timing kit, cam seals, and valve seals. Does anyone have any other suggestions?
I am also seriously considering deleting the sunroof (I really don't like a lot of weight up high).
1995 SR, dark blue, cloth seats, flare and cladding delete, upcoming sunroof delete,10 Guage custom skid plates, ham radio
Re: Head gaskets, what else? [Re: marksroberts61] #1102487 11/21/16 10:14 PM
P
pcc Offline
Water pump, crank seal. My PCV valve is under the intake, if yours is then maybe a new one. Valve cover gaskets. Send injectors out to be tested/cleaned. I use Witchhunter. Maybe look at some new, hard to get at hoses.
Re: Head gaskets, what else? [Re: marksroberts61] #1102488 11/22/16 01:32 AM
Yeah all of that was on the list except for the crank seal, I should probably change the crank pulley bolt too....
There is water in the oil, what's the best way to get all of that out?
Re: Head gaskets, what else? [Re: marksroberts61] #1102489 11/22/16 02:16 AM
P
pcc Offline
Water will be sitting at the bottom of the pan. Just do an oil change with filter. I wait until all work is done before adding new oil.
Re: Head gaskets, what else? [Re: marksroberts61] #1102490 11/22/16 02:32 AM
That's crank bolt and washer. And if you wanna really update, Ninja Performance sells lifters that have bigger holes which helps keep ticking down.
Re: Head gaskets, what else? [Re: Mudraider] #1102493 11/22/16 11:07 AM
P
pcc Offline
Or RockAuto, EngineTech. I'd get the spec on the size of the hole. I upgraded to the EngineTech L6000 and the hole was slightly larger and has helped with ticking, but I thought it would be even larger. I'm running 0W-40 M1 in NC.
I'm not sure what the ideal hole size is.
Re: Head gaskets, what else? [Re: marksroberts61] #1102494 11/22/16 03:49 PM
Thanks guys! I'll look into the VLA's, and check the butterflies of course. On the last SR I just cut the butterfly shaft off just inside the plenum, California truck, outwardly looks stock to smog techs, actuates and everything, lol!
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6181 MB (Peak: 0.6929 MB) Data Comp: Off Server Time: 2026-10-22 07:40:59 UTC
