Tip for Gen2 Swaybar Endlink Removal #1102575 12/07/16 10:36 PM
BlueMont Offline OP
This may be obvious to some but tips like this are what really saves time on projects. I remember reading about some poor soul who spent hours trying to get the swaybar bushings off (the part that sticks to the lower control arm). I got mine off within minutes using this method.
Block off your cv boot/axle/shock with tin foil as a shield. Then use MAP gas torch to burn up the bushing in a well ventilated area, you have to burn out the area that is fused with rubber but it shouldn't take too long. I just had a small flame after heating it and blew it out after like 15 seconds or less. Take vice grips and work it back and forth and outward at the same time. You have to grip them on there pretty tight. Mine slid right off.
https://sli.mg/Y8BCBt
87 Mitsubishi Montero The old Beast
99 Montero with Winter Package No name yet
Re: Tip for Gen2 Swaybar Endlink Removal [Re: BlueMont] #1102583 12/09/16 03:11 AM
That's quicker than fighting it.
Re: Tip for Gen2 Swaybar Endlink Removal [Re: BlueMont] #1102648 12/17/16 02:06 AM
O
Omardottcom Offline
Is there a reason why it doesn't just come off using a ratchet on the bolt?
Owner of 1995 Mitsubishi Montero
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5922 MB (Peak: 0.6466 MB) Data Comp: Off Server Time: 2026-06-07 03:51:41 UTC
