4.90 Gears
#1102632
12/15/16 11:22 PM
Remember a thread from back in the day about using axles from a Montero Sport to have get 4.90 gears.
Believe the thread said, use the axles out of the 2001 or newer but cannot remember what model.
I've searched but can not find the thread. Can anyone point me to the thread or explain the process.
Also, can the axles be straight swapped or do the just gears get moved.
Thanks, ~ Jon
95 Montero SR 33 x 12.50 Aussie Locker OME Heavy Duty Coils & Torsion Bars ARB Front Bumper 76" Trail Gear Rock Sliders XRC-9.5K Winch
Re: 4.90 Gears
[Re: jdavis]
#1102636
12/16/16 01:25 AM
2 minutes using the Search function: Thread
Re: 4.90 Gears
[Re: jdavis]
#1102642
12/16/16 08:44 PM
Thanks Rxinhed!!
Not the thread I was thinking but a lot of information.
The thread I'm thinking might of been posted Offroader...
~ Jon
Re: 4.90 Gears
[Re: jdavis]
#1102644
12/16/16 11:52 PM
To swap the complete housing you need the AWD housing, you can ID these by the AWD badge on the truck or the lack of a vacuum disconnect on the diff (no rubber boot thingy. Otherwise if you are just taking the gears they will work in any Gen 2 Montero with 8" diff.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6014 MB (Peak: 0.6574 MB) Data Comp: Off Server Time: 2026-07-09 15:42:35 UTCValid HTML 5 and Valid CSS
