88 22re tps #1102662 12/21/16 12:49 AM
Bevoman Offline OP
Just after a bitter cold snap my 88 22re truck starts, runs 2-3 seconds, then dies . . . time after time. Pulled a code 41 - tps. Disconnected the tps and it does exactly the same thing as it does when connected. Sound like a bad sensor or something else?
Hook 'Em
Re: 88 22re tps [Re: Bevoman] #1102664 12/21/16 04:00 PM
4x4Wire Offline
Yes. Disconnecting a sensor doesn't cure problems related to it. Generally a TPS failure will cause a "limp home" condition where the engine still runs but very poor. With the code indicating TPS failure, replacing it should clear the code.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: 88 22re tps [Re: Bevoman] #1102665 12/21/16 07:06 PM
4x4Wire Offline
Another point to check....
As you indicated this happened after a cold snap, inspect your vacuum hoses for cracks/leaks. Hoses do get brittle as they age and slight engine movement could crack them.
John Stewart
Editor - 4x4Voice
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5956 MB (Peak: 0.6495 MB) Data Comp: Off Server Time: 2026-10-22 07:41:45 UTC
