Re: Engine Cylinder Repair/Re-sleeve? [Re: Lha1988] #1102899 01/31/17 10:12 PM
Stevie Offline OP
Just got off the phone with the machinist: They were able to "heat it and straighten it out" and finish the Valve Job and surface. Sounds like they saved it, of which I'm very happy. These heads are getting hard to find.
Off topic, but need an answer:
During the teardown, lot of the bolts which have Lock Washers pressed onto them have lost their "bend". I question their intended function now.
Anyone develop a way of bending the half while on the bolt?
Thanks for all the help.
Steve
'80 4X4 Longbed
Re: Engine Cylinder Repair/Re-sleeve? [Re: Stevie] #1102921 02/01/17 02:58 AM
L
Lha1988 Offline
I've never heard of heating up and straightening a head,but if it works,great! On the captive washers,I wouldn't think you'd be able to get the "set" back in them. that said,maybe they've just locked in place by friction and will spring back if you can get the ends apart by bending the washer in opposite directions. Good luck.
Re: Engine Cylinder Repair/Re-sleeve? [Re: Stevie] #1102934 02/02/17 03:18 AM
Heads don't heat and get straight...sounds like you spoke to Bruce Freeburn in Fontana, charlatan!
Why not scrap the 20R altogether and upgrade to the 22R?
Re: Engine Cylinder Repair/Re-sleeve? [Re: rxinhed] #1102949 02/03/17 02:46 PM
Stevie Offline OP
Thanks. I may not have described it in the right terms ("heat" they said), but got the head back from the shop, guaranteed.
AFA going to a 22R, I thought of that, but was told by the smog tech that if the truck doesn't have the original-typed engine (1980 = 20R), he can't certify it as passing CA Smog Check.
Steve
'80 4X4 Longbed
Re: Engine Cylinder Repair/Re-sleeve? [Re: Lha1988] #1102950 02/03/17 02:48 PM
Stevie Offline OP
Thanks. Will give it a shot.
Steve
'80 4X4 Longbed
Re: Engine Cylinder Repair/Re-sleeve? [Re: Stevie] #1103017 02/08/17 12:54 PM
Stevie Offline OP
Coming together.
Moly-B for anti-seize lube, and torqued to 75 ft/lbs.
Ready for piston/rod installation.
'80 4X4 Longbed
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.008s) Memory: 0.6218 MB (Peak: 0.7253 MB) Data Comp: Off Server Time: 2026-07-16 03:40:25 UTC
