Body panel stuff... #1103216 03/21/17 02:48 AM
hacker Offline OP
Whadya do when the whole truck looks good other than something like this here...
Could you just take it off and heat it up somehow, set on it's side and let gravity reshape it? Or would it be better to just peel it off and replace it with a straight one, either from a jy or new?
Also, whats a good solvent for getting the double sided tape residue off?
~~_/) ~~
www.maps.org
Re: Body panel stuff... [Re: hacker] #1103221 03/22/17 02:47 PM
4x4Wire Offline
Easy part is the solvent. There is a product I came across a few years ago called "Goof-off". Found it at Home Depot but you can get it on-line.
http://www.goofoffproducts.com/stain-solution-center
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
Re: Body panel stuff... [Re: hacker] #1103222 03/22/17 02:56 PM
4x4Wire Offline
The body panel....
Heating will damage the paint and sometimes warp the sheet metal more. There are body shop tricks I have seen where you drill a hole (or series of holes) and insert a cable and attach a flat steel weight. The cable is then tightened to pull out the dent.
John Stewart
Editor - 4x4Voice
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5956 MB (Peak: 0.6492 MB) Data Comp: Off Server Time: 2026-10-22 07:38:59 UTC
