Wheel referb #1103307 04/12/17 10:25 AM
hacker Offline OP
The wheels on the '96er have seen better days so I'm gonna spend some time and give them a face lift. I've got the darker colored version of the Jeep wheel called the Grizzly.
They've been scuffed some on the edges and that's led to the clear coat peeling.
I'm planning on generally following the directions in this video I found on refurbing wheels. Basically this guy uses a small 120 grit flap wheel on a Dremel to grind out some fairly deep gashes, followed by wet sanding with 400, 600, 1000 and 2000 grit. Then gets the clear coat off with stripper followed by polishing with a foam pad on a drill w/ Meguiar's Metal Polish.
After cleaning he adds the clear coat back with 3 coats of Rust-Oleum American Accents Clear Gloss.
Here's the 14 min video if you're interested...
How to Repair Rims with Curb Rash or Scratches
First question is...since I've got a two tone wheel how does this effect how I do the referb? I don't have any scratches in the darker spoke parts so no worries having to get into that. My grinding and sanding would only be in the lighter outer ring area.
And second, any recommendations for a stripper and a clear coat?
~~_/) ~~
www.maps.org
Re: Wheel referb [Re: hacker] #1103309 04/12/17 03:44 PM
4x4Wire Offline
Not positive but I believe the dark tones are a coating at time of casting. As long as you don't sand into the darker material, it should be ok. the color should withstand a stripper agent. I would recommend a spot check first to see if the stripper agent does also take of the dark tone color.
I haven't messed with paint strippers for many years. OSHA and EPA regulations have changes mixtures over the years. I do have confidence in Rust-Oleum products.
You might check with a local body shop to see what they use.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
PHP: 7.4.33 Page Time: 0.488s Queries: 15 (0.486s) Memory: 0.5874 MB (Peak: 0.6364 MB) Data Comp: Off Server Time: 2026-10-24 12:37:03 UTC
