Clutch Hydraulic Lines on Gen1
#1103758
08/22/17 06:20 AM
What's the general feeling about using a braided hydraulic line for the clutch? I am replacing the clutch master cylinder as it is leaking down under the clutch pedal and I'm not sure if I'll be able to get the fitting off without breaking it. It's pretty well rusted. I've been spraying it with PB Blaster the past couple of days but haven't been able to get it loosened up. It's too close to the wiring harness to apply heat, and I've never had that much luck with heat on brake lines anyway. I'm thinking it might be easier to use a braided line instead of trying to track down an OEM one or get a generic one bent to match.
What's the best way to approach this?
Thanks,
Alex.
---------------------------- AlexM. Limited Mechanical Skills '90 Montero RS 5-speed
Re: Clutch Hydraulic Lines on Gen1
[Re: AlexM]
#1103774
08/24/17 02:23 AM
I would loosen the entire shebang out through the top, lines and all, and replace the mass with OE
[Re: AlexM]
#1103775
08/24/17 05:37 AM
Thanks. Got the flare nut out of the clutch master cylinder without breaking anything, but wound up rounding the nut off a bit, even with a flare nut wrench (and some help from locking pliers when the wrench started to slip). I'd still consider replacing with OE. Looking on parts sites, there's a part "MB555111" that says it is "Hydraulic Lines" and is in the category "Transmission:Hydraulic System" with but I can't find any diagram of it to verify it's the right part. I'll keep looking.
Always appreciate help from this forum. Thanks.
Alex.
[Re: AlexM]
#1103811
09/03/17 08:46 PM
Check the Mitsubishi ASA program. You need a Windows PC and can download it from Mitsubishilinks.com. It will use your VIN to give you the exact p/n's.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6059 MB (Peak: 0.6625 MB) Data Comp: Off Server Time: 2026-05-29 15:17:34 UTCValid HTML 5 and Valid CSS
