coffee shorted fuse box
#1103996
11/29/17 05:34 AM
I thought somebody'd get a kick out of this story. I had a parasitic loss that ruined a battery. I finally tracked it down to multiple fuses/fuse holders shorted with old spilled coffee. After a bunch of troubleshooting I flipped some fuses so all the numbers were facing the same way because it botherred me. Suddenly the short was gone. I looked closer at the fuses and fusebox and saw the sticky goo. I hosed it all down with electronics cleaner and wiped off each fuse blade. I can't say absolutely for sure if that was it but I have no better theory. I'll keep an eye on the new battery, test my tester, and maybe update here if I find something different. Moral of the story is Don't put your drink on the flat spot on the left of the dash of a gen1.
Also, I got a Northstar group31 marine battery. It's badass.
87 Dodge Raider 5sp 2.6l no jet valves, Tuffpan OME Dakar leaf springs + T-bar crank + 2" body lift (4" lift). 5500lb winch, Starion alternator, grp31 marine bat' OBA (stock AC compressor) 33x12.5x15 Baja Claws or Wintermark extra load 235/75/15 M/S
PHP: 7.4.33 Page Time: 0.006s Queries: 14 (0.004s) Memory: 0.5820 MB (Peak: 0.6222 MB) Data Comp: Off Server Time: 2026-07-09 16:13:30 UTCValid HTML 5 and Valid CSS
