relay module ID - need help #1104090 01/19/18 06:51 AM
jeffmort Offline OP
I am trying to specifically identify what these two relays are. I have a 91 Montero and they are both located in the passenger side foot well area.
Jeff
1991 Montero
Re: relay module ID - need help [Re: jeffmort] #1104098 01/21/18 12:20 AM
The larger one is for the auto hubs lighting circuit. What are the numbers on the greenie one?
Re: relay module ID - need help [Re: jeffmort] #1104101 01/21/18 12:30 AM
jeffmort Offline OP
Thank you. Green one has no part #'s on it.
Jeff
1991 Montero
Re: relay module ID - need help [Re: jeffmort] #1104103 01/21/18 12:34 AM
Where in relation to the other do you think the green unit occurs on the wiring schematic? What color wires in the plug?
Re: relay module ID - need help [Re: rxinhed] #1104108 01/21/18 02:29 AM
dfreem01 Offline
The green one is the rear window defroster relay.
Re: relay module ID - need help [Re: jeffmort] #1104109 01/21/18 03:24 AM
jeffmort Offline OP
Thank you.
Jeff
1991 Montero
Re: relay module ID - need help [Re: jeffmort] #1104111 01/21/18 04:27 AM
dfreem01 Offline
If it's good, keep it dry and happy. 2/3 of mine were corroded to disrepair. No way to fix them. Both of them forced the defogger power on constantly, be that good or bad.
PHP: 7.4.33 Page Time: 0.011s Queries: 16 (0.009s) Memory: 0.6159 MB (Peak: 0.7048 MB) Data Comp: Off Server Time: 2026-07-17 06:27:49 UTC
