correct idle RPM for 91 Montero #1104094 01/20/18 05:32 PM
jeffmort Offline OP
When operating correctly and the engine warmed up, what should the idle RPM be?
Truck is a 1991 Montero 3.0.
Thanks.
Jeff
1991 Montero
Re: correct idle RPM for 91 Montero [Re: jeffmort] #1104095 01/21/18 12:12 AM
According to the FSM. Page 14-55:
Curb idle speed is 700 +/- 100 rpm
Re: correct idle RPM for 91 Montero [Re: jeffmort] #1104104 01/21/18 12:35 AM
jeffmort Offline OP
Thank you. Is adjusting the throttle body screw or to lower the idle a proper fix or is that a band aid approach?
Jeff
1991 Montero
Re: correct idle RPM for 91 Montero [Re: jeffmort] #1104106 01/21/18 12:38 AM
Everything has to be adjustable, right? Otherwise, no adjustment screw?
I'd adjust there and see what results. Adjustment screws can normally be reset (or set back) easily.
Re: correct idle RPM for 91 Montero [Re: jeffmort] #1104110 01/21/18 03:32 AM
jeffmort Offline OP
adjusted - all is good now - thank you.
Jeff
1991 Montero
Re: correct idle RPM for 91 Montero [Re: jeffmort] #1104115 01/21/18 06:02 PM
Muy bueno
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6107 MB (Peak: 0.6802 MB) Data Comp: Off Server Time: 2026-06-09 21:41:19 UTC
