WTB GEN-I Montera Parts #1104304 04/30/18 01:34 AM
chadzeilenga Offline OP
Hi All,
I'm working through my first Montera. It is a 1989 LWB with White over beige interior. Overall in good shape, but looking for the following parts to start with:
- Factory radiator
- Factory fan shroud
- Coolant temp sensor (It's on the passenger side of the thermostat housing) - Prefer new, but used ok
- (2) Mitsubishi key blanks
- Oil Pressure sending unit - I think this is found at the oil filter base. My gage is currently dead
- Working horn switch. This is the button that makes contact and sounds horn.
- Straight & clean rear bumper - Mine has decent dent under spare tire.
I'm located in Charlotte, NC 28270. Willing to drive for any parts that are <3hrs away.
Re: WTB GEN-I Montera Parts [Re: chadzeilenga] #1104307 04/30/18 04:22 AM
Many of the new parts can be found at:
oemmitsubishiparts.com
Mitsubishi Parts Warehouse
Rock Auto
I have a fan shroud, easy.
The horn button in the steering wheel is normally the culprit. as the steering wheel plastic ages.
Re: WTB GEN-I Montera Parts [Re: chadzeilenga] #1104318 05/02/18 01:42 AM
Hi,
Thanks for the response.
For the bigger items, I'm looking for used (Radiator, Fan Shroud & rear bumper).
I have the oil pressure switch on order from MitsubishiPartsDirect.com, but no luck yet on key blanks. The horn button I have is missing all of the foam that kept the 2 metal parts separated. I haven't seen it available on any of the OEM sites.
I have not been able to find the AC Temperature Switch (mistake in prior post) at any of the OEM sites, nor can I find a P/N for it.
Re: WTB GEN-I Montera Parts [Re: chadzeilenga] #1104363 05/28/18 01:40 PM
bearingman Offline
PM sent. 910-416-2732 Fayetteville NC I have whole Monty with bad engine from a 94 in it and original 89 V6 (seized) WITH NC title if I can find it. Come get it on trailer. $300.00. I don't want it crushed
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6003 MB (Peak: 0.6567 MB) Data Comp: Off Server Time: 2026-07-14 05:12:55 UTC
