87 Raider instrument cluster woes #1104479 07/26/18 04:42 PM
melohman Offline OP
I have an 87 Raider, 2.6 auto. The speedo and tach donÔÇÖt work, the fuel gauge only goes to 3/4, and the temp gauge quickly rises to the top once I start the engine. IÔÇÖve replaced the fuse and pulled the cluster and looked carefully at the connections and circuit board. Nothing appears amiss. Any ideas?
87 Raider, 2.6 auto
Re: 87 Raider instrument cluster woes [Re: melohman] #1104481 07/26/18 06:21 PM
dfreem01 Offline
I think you'll just have to replace those. They're not user serviceable. I've gone through 4 fuel/temp gauges recently until I found one where both sides worked. My speedometer is 5 MPH off but I'll take that...could be other things, too, that I don't care to troubleshoot.
Re: 87 Raider instrument cluster woes [Re: melohman] #1104482 07/26/18 11:34 PM
1. Speedo is mechanical, not electric
2. Fuel gauge is dependent upon the signal from the fuel level sender...that is likely corroded, common problem after all these years
3. If the temp gauge is rising quickly, you could also have an issue with the temp sensor or blown head gasket
4. The tach...check your ignition coil connections
It will behoove you to look up and download the factory service manual (FSM) from mitsubishilinks.com and review the troubleshooting portions.
If all else fails with the FSM review and you determine that you do indeed have a defective gauge cluster, look me up. I have a few clusters for sale.
Cheers,
Russell
Re: 87 Raider instrument cluster woes [Re: rxinhed] #1104484 07/27/18 12:41 AM
melohman Offline OP
Thank you!
87 Raider, 2.6 auto
Re: 87 Raider instrument cluster woes [Re: rxinhed] #1104486 07/28/18 04:08 PM
melohman Offline OP
Looks like I need a cluster, rxinhed. Sent a pm.
87 Raider, 2.6 auto
Re: 87 Raider instrument cluster woes [Re: melohman] #1104489 07/29/18 10:10 PM
K. Have been away. I'll weigh and the like, prepare a shipping estimate
Re: 87 Raider instrument cluster woes [Re: rxinhed] #1104492 07/30/18 03:02 PM
melohman Offline OP
Thanks!
87 Raider, 2.6 auto
Re: 87 Raider instrument cluster woes [Re: melohman] #1104494 08/01/18 03:07 AM
Sorry to report the two clusters I have a V6...different tach. Bummer for me to not have this.
Re: 87 Raider instrument cluster woes [Re: melohman] #1104497 08/02/18 03:37 PM
melohman Offline OP
Hey, thatÔÇÖs ok. Thanks for checking.
Anyone else out there have a good 2.6 cluster theyÔÇÖd sell?
87 Raider, 2.6 auto
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6268 MB (Peak: 0.7134 MB) Data Comp: Off Server Time: 2026-06-17 03:39:59 UTC
