Tire/Wheel pics
#1104722
11/28/18 03:18 AM
Newbie, I've searched the forums with little results. Looking for tire and wheel setups and backspacing/offset numbers. I'm looking to put on 32x11.5r15 on AR172 Baja 15x8, with a 3.75 bs/-19mm os. Any input?
Re: Tire/Wheel pics
[Re: 99Monterrible]
#1104730
12/09/18 01:31 AM
Do the Gen3 Montero not require 16" rims to clear the caliper?
You'll be underwhelmed by the MudStar tires. I wore a set out in 20K miles on a Dodge Raider.
Re: Tire/Wheel pics
[Re: 99Monterrible]
#1104732
12/09/18 06:11 PM
I don't know about the caliper clearance on a Gen3. Thanks for the feedback back on the tires, now wondering what average lifespan for muds is!
Re: Tire/Wheel pics
[Re: 99Monterrible]
#1105634
07/27/20 11:03 AM
I don't know much about the proper set up of tire and wheels for the Gen3 Montero. However, I looked it up and found a few compatible wheel and tire packages for your said vehicle. Whether you're looking for main tires or spares, this might help you visualize your intended setup.
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6066 MB (Peak: 0.6868 MB) Data Comp: Off Server Time: 2026-11-02 10:59:14 UTCValid HTML 5 and Valid CSS
