WTB - Mitsubishi OD Relay MB510843 #1104795 01/09/19 03:56 AM
tdf46 Offline OP
My rig is a 1989 Montero LS LWB, but this relay is likely used in several models and years to shift the K148 automatic transmission into overdrive.
I had to remove the ECM and heater plenum to find it under the dash on the passenger side
You can post a reply here or send me a PM.
I'm located in Pierce County WA but would be an easy item to ship from anywhere.
Thank You
Re: WTB - Mitsubishi OD Relay MB510843 [Re: tdf46] #1104801 01/12/19 12:15 AM
tdf46 Offline OP
The P/N for this relay is MB510843. It is no longer in production, so your not going to find one at NAPA or Rockauto.
If you are interested, read my post in Mitsubishi Tech on how I worked around this issue!
Enjoy your rig!
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5873 MB (Peak: 0.6356 MB) Data Comp: Off Server Time: 2026-07-13 15:47:37 UTC
