Tailgate Hinge Assembly: Part No & Diagram? #1104832 01/30/19 08:17 PM
Crops Offline OP
Hi Guys -- my tailgate hinge assembly in my 95SR seems to be failing - the (I think) plastic bushing inside the hinge assembly has deteriorated and the metal pin has rusted and possibly broken (the upper hinge). The lower hinge seems to be bearing the weight and the upper hinge seems to be floating... see photos here:
Does anyone have a better diagram for this assembly? or part numbers for the internal bushings (if that's what I need) or any spec on them?
Regards
Rob
89 Raider V6
95 SR Montero
Re: Tailgate Hinge Assembly: Part No & Diagram? [Re: Crops] #1104834 01/31/19 06:04 AM
See the diagram and parts schematic here:
tail gate
Re: Tailgate Hinge Assembly: Part No & Diagram? [Re: rxinhed] #1104835 01/31/19 06:42 PM
Crops Offline OP
Thanks Russel. When I look at this diagram I do t see anything that looks like the hinge components beyond the fact that the have a ÔÇ£hingeÔÇØ.... would this suggest that the upper hinge for example is an assembly (the pins and bushings etc) and the diagram just doesnÔÇÖt look like what I expect (that the sketch isnÔÇÖt particularly accurate). Many thanks.
EDIT: When I google the part number I get pictures of the hinges as an assembly so my assumption is the diagram is just not particularly accurate with respect to showing the part correctly.
89 Raider V6
95 SR Montero
Re: Tailgate Hinge Assembly: Part No & Diagram? [Re: Crops] #1104838 02/02/19 05:52 AM
The hinge is sold as an assembly, if still available, not the component 3 pieces.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6031 MB (Peak: 0.6602 MB) Data Comp: Off Server Time: 2026-05-29 16:41:33 UTC
