97 montero replace boot or axel? #1104879 02/26/19 12:25 AM
MMeadows Offline OP
I have a 97 montero that shredded its boots when the tire came off the rim. Its winter so normally i would just take the car in to a shop, but everyone is quoting me for a new axel at $500+ installed, that the labor doesn't make sense to just replace the boot.
Ive looked online but i cant find anything about replacing the axel, but im assuming it can be too complicated, as im sure it can be replaced on the trail?
Has anyone replaced the boot or axel in there montero? Is there a write up on here that im just not finding? Do i really have to get another alignment after replacing the boot?
97 Montero SR: 2in body lift. 33" KM2
Re: 97 montero replace boot or axel? [Re: MMeadows] #1104880 02/26/19 05:21 AM
_
_na3s Offline
Not such a difficult job and new boots are pretty cheap - http://www.4x4wire.com/mitsubishi/tech/inner_cv/
'87 D50
Re: 97 montero replace boot or axel? [Re: MMeadows] #1104882 02/26/19 12:27 PM
Bigshankhank Offline
Axles aren't tough to replace, IIRC you have to remove it in order to replace the boot anyway so why not just get a reman axle and swap it in?
1989 Dodge Raider V6
2001 Jeep Wrangler 4.0L
2008 Toyota 4-Runner SR5 4wd
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5922 MB (Peak: 0.6457 MB) Data Comp: Off Server Time: 2026-05-29 16:35:36 UTC
