GEN1 6G72 Fuel Pressure #1104900 03/07/19 10:03 PM
chadzeilenga Offline OP
Hi All,
I have a GEN1 that I'm trying to sort out after engine replacement. I have a question regarding checking fuel pressure. I have my fuel pressure gage installed on the fuel filter inlet banjo fitting.
With everything connected I get ~42-44psi on (2) different Fuel Pressure Regulators. FSM states this should be 38psi.
When I disconnect the vacuum line to the FPR I get 53psi, which is within specification of the FSM.
I'm confused about the 38psi from the FSM. Is this a MAX limit? Would only 4psi above that cause issues?
Re: GEN1 6G72 Fuel Pressure [Re: chadzeilenga] #1104903 03/09/19 11:15 PM
Is there another port along the fuel rails on the engine? Has been a long time since I looked.
Re: GEN1 6G72 Fuel Pressure [Re: chadzeilenga] #1104906 03/10/19 02:34 AM
Hi Rx,
Not that I can tell. Just the connections from flex line to rail and FPR. Looks like there is a special adapter in FSM to measure at the rail.
Re: GEN1 6G72 Fuel Pressure [Re: chadzeilenga] #1104914 03/16/19 10:07 PM
MarkG Offline
I used to have the adapter hose. I can look next week. It replaces the high pressure line from the firewall to the engine. It has an inline T with a schrader valve to check the pressure. Someone could make one themselves by splicing in a T and a schrader valve.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6021 MB (Peak: 0.6579 MB) Data Comp: Off Server Time: 2026-06-21 20:21:29 UTC
