Question about alternator upgrade - wiring #1104919 03/18/19 10:53 PM
G
GrantCee Offline OP
IÔÇÖm preparing to drop in a Starion 75-amp alternator in place of the 50-amp unit in my ÔÇÖ87 4-cyl. However, IÔÇÖve been looking at the charging wire running from the alternator, and itÔÇÖs a pitiful thing; I havenÔÇÖt measured the conductor to be sure, but it looks like no more than a 10-gauge wire.
Looking at wiring charts, it tells me that a 5-foot run (which is about what it is from the alt to the battery) at 75-amps requires a 4-gauge wire. ThatÔÇÖs a big difference from whatÔÇÖs in there!
Should I upgrade that stock wire before putting the new alternator in?
1987 Montero SWB, 2.6L, 5spd
Weber conversion
2-valve head from Engine Machine Service
"4G54 FTW!"
Re: Question about alternator upgrade - wiring [Re: GrantCee] #1104920 03/21/19 02:02 PM
Bigshankhank Offline
What little I've learned from restoring motorcycles and working on cars for 30 years is, manufacturers do not put more than what is needed in their electrical systems, because on a production scale adding $0.10 to the cost of a single wire gets very expensive when they build thousands of them in a month.
In other words, the original wire was probably barely sufficient for the OEM 50-amp current, in addition to being 30 years old and having decayed in that time, you should upgrade it.
1989 Dodge Raider V6
2001 Jeep Wrangler 4.0L
2008 Toyota 4-Runner SR5 4wd
Re: Question about alternator upgrade - wiring [Re: Bigshankhank] #1104921 03/22/19 08:13 PM
G
GrantCee Offline OP
I've decided to replace that wire with a 4-ga wire and a slow-blow ANL fuse. That should cover everything.
Weber conversion
"4G54 FTW!"
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.5927 MB (Peak: 0.6465 MB) Data Comp: Off Server Time: 2026-07-14 20:14:25 UTC
