Re: 89 v6 Reluctant To Start After Rain/Snow [Re: polar] #1105279 10/08/19 12:07 AM
P
polar Offline OP
UPDATE: OK - changed out Distributor O-ring and added even newer plug wires and STILL having reluctant starting on wet mornings!
Any other suggestions? Maybe Ignition coil?? .....Ignition Relay switch??
Re: 89 v6 Reluctant To Start After Rain/Snow [Re: polar] #1105280 10/08/19 11:05 AM
cheesegrater Offline
Re: 89 v6 Reluctant To Start After Rain/Snow [Re: polar] #1105282 10/09/19 02:16 AM
P
polar Offline OP
Thanks for the reply Cheesy
I watched that video and tried spraying water on the Coil with the car running............ And It Stalled Right Out!
I unpluged both coil connections and they were dry but the T connector had a little electrode corrosion. I used sandpaper and cleaned the T and wiped off any moisture and it fired right back up!
So car stalling out when coil is wet means..... what? It's shorting out?.....but why, from age? Replacing the Coil is next I guess.
Re: 89 v6 Reluctant To Start After Rain/Snow [Re: polar] #1105283 10/09/19 10:16 AM
Sorry that didn't help. I'll keep looking. If I come up with anything, I'll post it.
Re: 89 v6 Reluctant To Start After Rain/Snow [Re: polar] #1105284 10/09/19 09:11 PM
P
polar Offline OP
Hey Cheesy Oh no, I think it did help. I pinpointed the coil shorting out the car when wet as having a crack or defect, so ordered a new one.........so yeah, that did help.....we will see when I put the new one on if that solves the problem.
Thanks again!!
Re: 89 v6 Reluctant To Start After Rain/Snow [Re: polar] #1105297 10/19/19 08:02 PM
P
polar Offline OP
Update: Starting problem seems to be solved! Yeah!! Not one problem starting since replacing ignition coil!!!
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6173 MB (Peak: 0.7034 MB) Data Comp: Off Server Time: 2026-10-24 08:16:56 UTC
