Rear Raider Wiper not Working #1105251 09/16/19 01:21 AM
red1987raider Offline OP
Hey guys. Rear wiper on '87 Raider stopped working. Dash switch is good but put the multimeter to the motor and it's not getting power. Removed motor and tested it ÔÇö works fine. Auto wiring is my weak link. Any ideas for trouble shooting this thing? Many thanks!
1987 Dodge Raider converted to 4D56T
Re: Rear Raider Wiper not Working [Re: red1987raider] #1105252 09/16/19 11:08 AM
cheesegrater Offline
Unless you're a stickler for authenticity, the first thing to do is to run a jumper wire from the switch to the motor with everything in place to see if all works that way. If it does then just run a new wire to the motor and put it under the door sill, through the fender and through the hole into the rear door.
Re: Rear Raider Wiper not Working [Re: red1987raider] #1105256 09/19/19 11:14 PM
P
polar Offline
I like Cheesey's smart thinking!!
Re: Rear Raider Wiper not Working [Re: red1987raider] #1105266 09/23/19 12:22 PM
Thanks, Cheesegrater. I think I'll have to go that route. But just for the sake of knowing, I'm still wondering where the problem lies with the stock set-up.
Re: Rear Raider Wiper not Working [Re: red1987raider] #1105356 11/20/19 05:42 AM
tbonesdam Offline
Mine has done the same thing. Does your rear window squiter work when button is depressed? Mine doesn't but button does function just not in this Montero. Wondering if you found culprit.
SELF MADE CHOP TOP W/HARD TOP.87 5 speed 2.6 less Balance shafts.Raider 88 Rust-O-loomed Body.Herculined Interior.Rust-proofed Frame.(Eastwood Stuff)Prothane Bushings.33x12.50.3in. Body Lift.2in. SHackle Lift + Torsion Crank.
89 Dodge Raider V6 Auto
90 Mitsu Montero LS so Clean!
Re: Rear Raider Wiper not Working [Re: red1987raider] #1105357 11/20/19 02:59 PM
4x4Wire Offline
Automotive electric issues are often caused by ground issues - specifically, rusted or corroded ground points.
John Stewart
Editor - 4x4Wire.com
Editor - 4x4Voice
Editor - MUIRNet-News
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6091 MB (Peak: 0.6790 MB) Data Comp: Off Server Time: 2026-07-17 02:19:06 UTC
