88 Dodge Raider Parts #1105335 11/11/19 05:18 PM
P
Patchman Offline OP
Hello,
The timing chain died in my boy's 88 Raider. I swapped in a Jeep 2.5L/AX-15. Don't need some of these old Mitsubishi parts.
The engine is already gone, but I have the following:
Trans/transfer case (have to be stopped to get it into first due to worn 1st gear synchro. Other gears and transfer case work fine.)
Flywheel / pressure plate / clutch
Ignition coil
Alternator
Clutch fan
Front driveshaft
Clutch master & slave cylinder
Starter (recently rebuilt)
Power window regulator (motor works)
If you live nearby, everything for $50 or make offer. Or PM me for individual parts and shipping to you. I have everything on CL, but no one around here seems interested...
I will post pics and description of the Jeep 2.5L/AX-15 swap on the forum later for those that are interested.
Thanks!
I'm in Michigan 48382.
Re: 88 Dodge Raider Parts [Re: Patchman] #1105342 11/14/19 03:57 AM
Jim Napiorowski is out your way.
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.5872 MB (Peak: 0.6360 MB) Data Comp: Off Server Time: 2026-07-15 08:01:13 UTC
