Time to Sell Raider #1105434 01/01/20 11:12 PM
Bigshankhank Offline OP
1989 Raider, V6 with 5-speed. 217k miles, I bought it in late 2018 to use as a daily beater to get to work. When I got it, I replaced the timing belt, water pump, shocks, brake calipers, rear brake cylinders, all new rubber and hard brake lines, pads and shoes, rebuilt the power steering pump, flushed the radiator and replaced the coolant lines and all belts. IÔÇÖve been sending oil samples to Blackstone labs and reports are coming back clean with metal content within normal levels. I switched it to semi-synthetic since I got it. Overall the truck runs great, stops great, doesnÔÇÖt overheat, and has been a very reliable daily rig. It has a small oil leak at the oil pump housing, and it burns some so monitoring oil levels is important. Sadly the A/C does not work, although the compressor and blower work so either find some R-12 for a recharge or convert it to R-134a. Body has some rust in the wheel wells, plus one of the hood hinges needs replacement. Interior shows it age, but other than the drivers seat itÔÇÖs not bad. Drivers seat spring-assisted frame works smoothly. Transfer case and auto locking hubs work. Tires have 20,000 miles on them, lots of life left.
Looking to get $2000 for it. Located in the Tampa Bay Area of Florida.
[Linked Image from i.ibb.co]
[img]https://i.ibb.co/26Qz4KB/3-B5-D381-A-B1-FE-4167-9813-3-ED8-C96654-A4.jpg[/img]
1989 Dodge Raider V6
2001 Jeep Wrangler 4.0L
2008 Toyota 4-Runner SR5 4wd
Re: Time to Sell Raider [Re: Bigshankhank] #1105435 01/01/20 11:14 PM
More pictures
Re: Time to Sell Raider [Re: Bigshankhank] #1105446 01/08/20 03:12 PM
Tuxedo_Ranch Offline
Tyler,
I haven't been online in a while and am sorry to see that you're getting rid of the Raider. Hope you stay around on the forum. Wish you the best of luck with what ever you decide.
LTUX
87 GEN1 Raider 5-spd w/ Weber (HAGAR)
87 GEN1 Monty 5-spd stock (LUCKY EDDIE)
88 GEN1 Raider A/T w/ Weber (HELGA)
87 Ford Ranger STX 5-spd 2.9L V6
95 Ford Bronco Eddy Bauer
99 Toyota 4-Runner Limited 3" lift
WELCOME TO MY "USED" CAR LOT
Re: Time to Sell Raider [Re: Bigshankhank] #1105461 01/22/20 05:53 PM
I appreciate it. I would love to keep it as it has been a blast to drive around and people are always asking me what the hell it is when I stop for gas. Plus there's a bunch of little stuff that I never got around to fixing that bug me to pass on to the next owner but it has served me well and should continue to serve whoever ends up buying it.
PHP: 7.4.33 Page Time: 0.219s Queries: 15 (0.015s) Memory: 0.6130 MB (Peak: 0.6941 MB) Data Comp: Off Server Time: 2026-10-24 04:20:26 UTC
