89 Dodge Raider for Sale #1105436 01/01/20 11:23 PM
Bigshankhank Offline OP
1989 Raider, V6 with 5-speed. 217k miles, I bought it in late 2018 to use as a daily beater to get to work. When I got it, I replaced the timing belt, water pump, shocks, brake calipers, rear brake cylinders, all new rubber and hard brake lines, pads and shoes, rebuilt the power steering pump, flushed the radiator and replaced the coolant lines and all belts. IÔÇÖve been sending oil samples to Blackstone labs and reports are coming back clean with metal content within normal levels. I switched it to semi-synthetic since I got it. Overall the truck runs great, stops great, doesnÔÇÖt overheat, and has been a very reliable daily rig. It has a small oil leak at the oil pump housing, and it burns some so monitoring oil levels is important. Sadly the A/C does not work, although the compressor and blower work so either find some R-12 for a recharge or convert it to R-134a. Body has some rust in the wheel wells, plus one of the hood hinges needs replacement. Interior shows it age, but other than the drivers seat itÔÇÖs not bad. Drivers seat spring-assisted frame works smoothly. Transfer case and auto locking hubs work. Tires have 20,000 miles on them, lots of life left.
Looking to get $2000 for it. Located in the Tampa Bay Area of Florida.
[Linked Image from i.ibb.co]
1989 Dodge Raider V6
2001 Jeep Wrangler 4.0L
2008 Toyota 4-Runner SR5 4wd
Re: 89 Dodge Raider for Sale [Re: Bigshankhank] #1105437 01/01/20 11:24 PM
More pictures
Re: 89 Dodge Raider for Sale [Re: Bigshankhank] #1105465 01/30/20 02:08 PM
*******SOLD*******
Re: 89 Dodge Raider for Sale [Re: Bigshankhank] #1105865 12/21/20 04:55 PM
KristianJ Offline
Whoever bought this Jeep, you may also need to buy yourself a set of Nitto ridge grappler tires, since those currently mounted tires do not seem to fit the ride anymore.
Re: 89 Dodge Raider for Sale [Re: Bigshankhank] #1105868 12/22/20 02:50 AM
How does this help a sales ad that is marked sold and is almost a year old?
Admin.
Moderated by  4x4Wire, code33, kewlynx
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6133 MB (Peak: 0.6987 MB) Data Comp: Off Server Time: 2026-05-28 01:03:54 UTC
