NP 235 T-case swap in Raider. ?
#1105617
07/12/20 06:52 PM
Hey gang,
I've been looking for the archived tech article on how-to put a NP 235 T-case on a Mitsu manual tranny. (88' Raider) I'm waiting a 4:1 crawler ratio. Thanks, Tres
--Tres (John 14:6)
Black 87' Raider 2.6L/Webber 88 5 Speed Welded front,tight LSD in the rear Removed bump stops 4'x6' roof rack 10k. Lb. winch on receiver hitch/custom bumper 100 amp alt CB radio/AC inverter S.Winch hubs Enormous RV battery
Re: NP 235 T-case swap in Raider. ?
[Re: TresMon]
#1105776
10/22/20 01:06 PM
--Tres (John 14:6)
[Re: TresMon]
#1105783
10/23/20 05:06 AM
I was reading somewhere you may be able to bolt 2 transfer cases together. But cant say if the was stock Monty cases or swapped in cases. If it was a divorced case like the Samurai's case is, that would be easy.
But im new to the mitsubishi team so i dont know much. Sorry i cant help.
91 (Gen1) Monty, 3.0L V6, Auto 4 Door. Disabled Driver.
[Re: TresMon]
#1105790
10/25/20 07:43 PM
The Aisin automatic is able to take the NP-231, but the stick trans is different. I've not read about stacked t-case in Montero. In the Toyota world, yes.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6011 MB (Peak: 0.6568 MB) Data Comp: Off Server Time: 2026-10-22 00:09:36 UTCValid HTML 5 and Valid CSS
