Re: Flying 1000mi to buy a 97 Montero SR sight unseen [Re: Macdrew77] #1105764 10/17/20 03:45 AM
You need to get an FSM, if you are ever going to go eye-balls deep into working on it. I don't have one for the 97s. Grab the 98 as there won't be major diffs between years for the 3.5 SOHC. Maybe grab the 96s too, as the 97s had both the flattys and the SR flared versions. (The 94-96 had the same LS vs SR exterior differences, and with different engines. The 97s had the same 3.5 SOHC.)
Also, I have a modest box of the small behind-dash bulbs if you need any. If you have a U-Pull junk yards near you, same era Mitsus of any model should get you lots of little bits.
Re: Flying 1000mi to buy a 97 Montero SR sight unseen [Re: Macdrew77] #1105768 10/20/20 07:53 AM
Macdrew77 Offline OP
Hey thanks for the offer, I actually just got all the bulbs I needed in from rock auto. And I did splurge on the 97 service manuals from eBay. The physical ones are so much nicer to use than the pdf copies out there.
I took it to Wheeler Pass on a 150mile trip to Pahrump, NV and back this weekend. Its a pretty easy but long (25mi maybe) trail up to 7500ft. Was nice to get some dirt under the tires but IÔÇÖd be lying if I wasnÔÇÖt nervous and paranoid about every noise I heard. Truck ran good, transfer case shifted and the appropriate lights lit up. The issues I had were a smell of fuel I noticed right after the steepest part of the trail (had me paranoid as hell and I checked everywhere for leaks but didnÔÇÖt see anything). And my oil pressure gauge is pretty much touching 0psi at warm idle. 30 while cruising. Got a mechanical gauge that IÔÇÖm gonna check with. ItÔÇÖs been reading low like that since I bought it, I cut open the old oil filter after 1500+miles and didnÔÇÖt see any metal.
Re: Flying 1000mi to buy a 97 Montero SR sight unseen [Re: Macdrew77] #1105769 10/20/20 08:08 AM
Some pics of the first trail for the '97 Pablo Montero
Re: Flying 1000mi to buy a 97 Montero SR sight unseen [Re: Macdrew77] #1105785 10/24/20 04:59 PM
dripdrip Offline
Sorry to hear you flew 1000 miles to pick up your monty. I had not listed mine yet! Mine is a 1997 ls with 1995 axles and locker. 190k miles body is worse than yours but probably most of my electrical is still working just fine. I am selling because I needed a rig that can pull bigger trailers.
Re: Flying 1000mi to buy a 97 Montero SR sight unseen [Re: dripdrip] #1105793 10/29/20 02:14 AM
Dang! Haha. Would be nice to have the gear ratio of the 1995 axles. How much do you think your rig is worth? I paid 2500
PHP: 7.4.33 Page Time: 0.006s Queries: 17 (0.004s) Memory: 0.6139 MB (Peak: 0.7120 MB) Data Comp: Off Server Time: 2026-05-25 19:00:50 UTC
